Introduction: Cheap Wall Mounted Bottle Opener With Cap-catcher
do you enjoy having a cold beverage on a hot day? do you hate looking around for a bottle opener every time? why not build a cheap, simple bottle opener that's always in the same comfortable location and will collect all the caps for you...
and its all built with things you can fine at home
Step 1: What You'll Need
part:
1 tall metal box ( i used a chocolate box)
15 CM (6") + height of box piece of wood
6 CM (2.3") piece of wood
1 small screw
1 medium screw
2 long screws
1 fridge magnet (like a pizza magnet)
tools:
drill
glue (epoxy/super glue or such)
Step 2: Put It Together
drill the medium screw into the small piece of wood, about 2 CM (0.8") from edge so only 2.5 (1") CM is showing.
drill the small screw about 2 CM (0.8") away from the first screw so only 1 CM (0.4") is showing.
hold this piece (screw faced down), try opening a bottle and correct screws location and depth if necessary.
connect the small wood to the large at a 90 degree angle using the two long screws.
glue the magnet to the long wood in the middle of where the box will go.
attach the box to the magnet.
secure the whole thing to something stable (i used duct tape and some shelves) and test it out before the final positioning.
attach your rig to the wall using a couple of screws/some glue or attach to your fridge if you have a really strong magnet
Step 3: Enjoy
4th Epilog Challenge
Hack It! Challenge
Pocket-Sized Contest
3 Comments
10 years ago on Introduction
Youtube says "video is private"
thanks. fixed it (i now understand why i couldn't embed it)
Ha, clever!
