Introduction: Chose Your Own Adventure or Watch Grass Grow
About: Im a chef, im a parent , also im an artist and was the studio assistant for the collage for several years I built haunted houses for 10 years did stage crafting for 6 owned my own carpentry business for 4 ye…
For this instuctable we will be dissembling a flat screen monitor the adventure will be up to you if you want to do
paint a monitor
Or fix a monitor
Or to create an original work of art
Or a planter
Or a solar night light
or all or none of the above
Step 1: Get Stuff Together
well to do this we will need some stuff and things!!!
Materials
Old Monitor
screw drivers
paint
scissors
glue gun
some wire
bits of metal perhaps
solar lights
moss
plants
and an Eveready pile of junk
Start by deciding if you even want to temp yourself with the grudging, toilsome task of completing this
Fairly easy project .you have the courage ? Then proceed to step 2 at your own peril
Step 2: Take Face Plate Off of Monitor
You decided to partake of this quest . You take off the face plate from the monitor by wielding your always reliable screwdriver you side the tip of your screwdriver into the dark foreboding channels at the bottom of the monitor and slowly pry the creaking (but fragile)plastic face plate off the carapace of the dead monitor
Continue?
Step 3: Removing the Buttons and Base
The next challenge awaits you Removing the screws that hold the buttons on there are 2 ya two screws that hold the buttons on you twist the wicked spirals of steel out of the plastic face plate and separate the two parts .Now the remove the base and release the dark contents inside . There are four screw securing the base to the plastic shell and also holding the actual monitor in as well A Baby attacks the work bench what do you do move the baby and continue? or retreat ?
Step 4: Time to Decide
decide now where to go as you pull the screen from the plastic housing if you want to just paint
skip to step 6
you decided to continue
you unplug all the diabolical wire that were glued in to there respective ports carefull not to tear them .Then there is a series of clipped frames holding the magic box together remove them one by one by placing your ever diligent screw driver in the slots removing the subsequent layers one at a time it could be dangerous or just plain neat . the plastic screen stuff is really cool to look at pictures do not give them justice one unparticular is magnifying and reflectiveco and clear there are plans for this
Step 5: Fixing Part
in the last frame there is a wavy edged piece of plastic with a pair of mini florescent bulbs these are what go bad and you can buy them and replace them about fifteen dollars or so
http://www.allelectronics.com/make-a-store/item/fl-122wh/set-of-2-ccft-lamps-white-w/inverter/1.html
if you just want to fix it stop here and replace parts and put it back together .
Want to get crazy with it Continue
Step 6: PAint
spray or even brush paint the shell of the monitor and put it back together if you just wanted to paint the monitor
or continue to the next step for forestation
Step 7: Geting Green With It
Warning this my disturb those who are techno pure and sensitive to electronic mutilation
put the case back together you will need some 1/4 nuts to hold the base on to the back then you go out side and collect some moss or if you are so inclined you can buy moss at a garden center or home depot . Hot glue the moss along the bottom of the monitor case and letting the case show threw in places is ok by me .
Step 8: Sticking to It
while outside it would be a good idea to find a stick or in my case it was a grape vine , you cut it to fit the screen and hot glue in the corners . Then you wrap bits of wire all over the branch leaving the ends loose I even added a piece of copper pipe strap .
Step 9: Leafing It Alone
so now take the magnifying clear and shiny sheet that was in the monitor and cut leaves and hot glue them on the wire ends of the branch
Step 10: Shinning Some Light on the Problem
get some solar path lights take the bottom off measure out the size of the light and cut out of the top insert the solar light and hot glue into place . I cut a slot in the base back on step 6 that I forget to mention it can accommodate a living plant to grow through just place a plant on the back side of the base and guide it in the hole and it will grow im tempted to plant some trees in there and see how it will grow around it .Now just have to find something to do with all the other monitor components
