Introduction: Club Car Driven Clutch Removal
in general if you have a driven clutch stuck on the shaft for me i have found the best way was to just bust off the aluminum and use a cutting wheel to split the clutch shaft. also if you have a clutch stuck on the engine remove clutch retaining bolt and fill hole with water then get a bolt that fits the threaded part of the clutch then tighten bolt the hydraulic pressure will pop the clutch free few light taps with mallet may be needed
Step 1:
Step 2: Time to Try It Out
this new clutch has alot more grab than the old one
