Coaster Bottle Opener
Intro: Coaster Bottle Opener
With Spring here many people are enjoying the the warmer weather, spending more time outside enjoying a cold one on the patio with friends. A common conundrum when entertaining friends is keeping the bottle opener from wandering away; unless you have the bottle opener chained up it's bound to get lost at a social.
Never be far from an opener to crack your next beer, all while keeping water rings off your tables. This bottle opener is cleverly placed under your drink coaster, making a few ensures that every guest has their own opener.
This easy woodworking project requires a biscuit cutter to make, but you might be able to make do with other tools. These coasters can be personalized, and they are infititly useful
In case the video wasn't enough; let's make!
STEP 1: Cut Wood Stock to Size
Using a table saw I ripped the wood plywood stock into 3.5" wide strips. These strips were taken to the chop saw next and cut into 3.5" sections, leaving a square blank which will be milled.
STEP 2: Mark Midpoint on One Edge
Using a pencil a mark was made.
STEP 3: Mark Depth
STEP 4: Buscuit Cutter
A biscuit cutter is used to cut a small slot into wood. Typically they are used to cut slots which allow a biscuit (a small thin piece of wood) to be inserted which joins two pieces together. For this application, we'll be using the biscuit cutter to remove a small section of wood from the bottom of our coaster by making a series of cuts on top of each other, creating a cavity.
before cutting the depth needs to be set on the biscuit cutter. You'll want to make a cut that's deeper than about half the diameter of a bottle cap. Most bottle caps are about 1" in diameter, so your cut will need to be a little larger than 0.5" deep. Once the depth gauge is set on the biscuit cutter we can start cutting.
Clamp a coaster blank to a sturdy work surface with the midpoint mark accessible. Lining up the midpoint mark with the centre guide of the biscuit cutter, plunge into the wood. Leaving the biscuit cutter flush against your work surface, shim the coaster blank with a thin piece of wood and clamp down again. By raising the coaster blank and repeating the biscuit cut you'll have made another cut right on top your previous cut, enlarging the opening. Repeating this process with larger shims will allow you to make a uniform cavity in the coaster blank.
Using a sharp utility knife clean up any burrs in cavity. Then use a medium grit sandpaper (~200 grit) to make a smooth surface.
STEP 5: Screw
Screws come in a wide variety, for this opener we'll need a screw that has a flat underside. Tapered screw heads will not grip the bottle cap and are not suitable.
I used 1/2" dome flat-headed screws, but any screw with a flat underside will work.
You could get away with just using one screw, but by using two you get a better connection with the bottle cap and there's less positioning when trying to open a bottle. Using a drill, two small pilot holes were drilled and the two screws were installed near the apex of the curved cavity. Ensure not to screw too far into coaster, else your screws will protrude out the top of the coaster.
STEP 6: Optional: Embellish
You could leave the tops of your coasters blank, but not embellishing this space seems like a waste
To personalize these bottle opener coasters I decided to etch the top. You could do wood burning, decoupage, or paint. I have access to a laser cutter so I decided to use it to etch an image onto mine - a simple beer bottle and can with a note letting you know there's a bottle opener hidden underneath.
STEP 7: Finishing
Before you can use your coasters you'll want to finish them with a sealant so they don't get damaged with use from wet bottle condensation. I finished my coasters with Danish oil, a tough water-resistant finish that can be applied with a rag.I love the easy application and rich colour it gives wood.
STEP 8: Crack a Cold One
Once the finish has dried your coasters are good to go! Make a few and have them around at parties, and personalize them to suit your style.
Cheers!
Have you made your own coaster bottle opener? I want to see it!Happy making :)
24 Comments
turtle keeper 8 years ago
I also made a wooden bottle opener,But it isn't like yours check it out.
https://www.instructables.com/id/Wooden-keychain-bo...
mikeasaurus 8 years ago
Looks good. How do you like it?
love it
buck2217 8 years ago
Great idea -encourage people to use a coaster!! the wife will be pleased!!
agis68 10 years ago
No doubt its excellent use of woodparts etc....BUT!!!
Its also time to give an idea to administration to separate all these instructables where machine expensive machines take place and involved with the object. The reason is simple....I can't compete all these guys have money enough to spend to buy or even rent any of these expensive machines.
So please take ithis advice under your consideration. I have excellent ideas (like most here) but with luck of money i can't execute so perfect if i had a lazer engraver or any cnc macchine....tell me your opinion on this
Geeks with lasers 10 years ago
Was just wondering what to do with the spare bits of wood i have upstairs. Time to make some custom coasters. Now i just need a laser engraver...
Bilou 10 years ago
Nice stuff... Instead of two screws, I've seen someone using a countersunk washer and a screw for the openning lever... It look awsome too... you may want to try it out...!
https://www.facebook.com/LaBizounerie/photos/a.542745519136079.1073741827.418960574847908/544358075641490/?type=1&theater
depotdevoid 10 years ago
Very nice, this looks awesome!
elicitone 10 years ago
That is an awesome Idea... and just in time!My Dad had me designing some Coasters to be made on his CNC machine. After seeing this, I have to rethink my design! :)
hyperfocused72 10 years ago
Now this is how you write an instructable. Simple idea, illustrated with clear pictures in the proper sequence and attention to grammar and spelling. Everything you need to know and nothing you don't. This ought to be an example for newbies in the FAQ somewhere. Well done.
sandroknexmaster 10 years ago
Nice project!
blueangelical 10 years ago
rimar2000 10 years ago
Nice design!
hunter999 10 years ago
Wow! Your full of ideas, awesome Instructable - very well documented. Thumbs up for Mike again for another amazing 'Ible! :-)
Voted!
eschmith 10 years ago
I absolutely love the instructable and the design of the top of the coasters. I do however think that those 2 screws don't look great, and will probably rip off of the coaster in no time. Though I'm not a woodworker, I'd probably take two squares (each half the thickness), still cut out the curved opening, but route a shallow square or rectangle on the "inside" surfaces of one or both halves and insert a sturdy bit of flat metal stock to act as the lip which would catch the cap. Drawing attached with dotted line showing area that I would route out to hold the stock. Then I'd epoxy or wood glue the remaining 3 sides together.
mikeasaurus 10 years ago
Thanks! The screws have plenty of bite in the wood, they're not going anywhere.
I considered a laminated approach (per your picture), but decided to try this way. You should post an Instructable on your version trying it out!
Mrballeng 10 years ago
This is great. And way to set the bar for an instructable. I applaud all the camera angles, the gif, and text on pictures.
That's some high praise coming from you, sir. Thanks!
JonnyBGood 10 years ago
You sir, are a genius! You have combined two elements that should have been combined a long time ago and I thank you for it. I also liked the instructions within the picture and I plan to try that back in the knex section.
Glad you like it!
