Introduction: Coffee Cup Poop-shaper
Boring while you take a poop? and boring with the shape of your poo? make a poo-shaper and entertain yourself by making amazing shapes with your poo with out getting your hands dirty!!!
NOTICE: This instructable can be used by any person with any age and gender.
Step 1: Things You Will Need
Here are the things you will need for making the coffee cup poo-shaper.
Tools:
-razor knife
-pen (ball pen)
Materials:
-paper coffee cup
-string (around 1m)
Step 2: Planning Your Shape
get the coffee cup and draw the shape you want your poo to be on to the bottom of the cup
Step 3: Cutting the Shape
cut out the shape with your razor knife.
Step 4: Making the Holes for the Strings
make a small hole on each side of the coffee cup with your pen.
Step 5: Cutting the Strings
cut two strings both around about 40cm long.
Step 6: Finishing of the Coffee Cup Poo-shaper
poke the strings through the holes and tie a not at the ends of the strings inside the cup to secure the strings.
Step 7: How to Use It
put the end of the cup with the shape to your butt hold the strings and poo!!!
Step 8: Tips
here are some tips that may help you if you have any problems with making the coffee cup poo-shaper if the tips don't help your problems then make a comment on the problem and i will try my best to help solve the problem and add it to the tips list.
1. choose a smaller sized coffee cup if your butt is small and choose a bigger coffee cup if your butt is fatter.
2.the length of the string may not fit you so if you are fat you can use a longer string and if you are skinny you can use a shorter string.
3.don't cut the shape too small because the poo may not go through.
have
4. do not use the coffee cup poo-shaper when you are constipated or when you have diarrae.
5. eat more vegetables before you use the coffee cup poo-shaper.
6.place your coffee cup poo-shaper directly to your butt-hole so the poo goes directly in the coffee cup poo-shaper.
so now you have a finished coffee cup poo-shaper enjoy your poo!!!
please rate comment and subscribe if you liked this intructable.....
have
