Introduction: Coil Gun
disclaimer: this is dangerous and involves high heat , voltage and some chemicals. proceed at your own risk. im not liable for any injury and only you can be held responsible for what you do.
ok now for the actual instuctable.
(by continuing to read you fully agree to the disclaimer at the top of the page)
what a coil gun is..
a coil gun is a gun that uses a elector magnet to fire a ferrous material buy pulsating the magnet to pull the material forward but not long enough to pull the material back to the center stopping the magnet from retracting the projectile. now the materials:
copper magnet winding wire
supper glue
nails cut to 12/16 in (ammo)
12 v dc power supply ( im using a psu from a old pc)
wood to make the handle
a momentary switch
wire (to make connections)
3 short wood screws(or more)
tape ( painters tape works well)
a small diode (if concerned about power supply putt in line with the coil)
now if your like me all of this should be laying around if not im guessing it shouldn't cost you more than 20 $.
tools:
al
soldiering iron
solder
snips
nails
screws
helping hands
wood working tools.
Step 1: The Coil
put a round object the size of your coil in the chuck of a drill
then wind winding wire around it
wrap in tape
drip glue through tube to hold it to its self
let dry
sand or burn the vinal of both ends of the wire
tin both ends with soldering iron
test with 12 volts dc (ac will not work)
Step 2: Electronics
there is a picture of the schematic.
+12--------->/ .--------------------------coil-------_ground
understand...
i dont.
just look at the pic not the text art.
note the picture of the competed circuit is a different one then in the final gun.
Step 3: The Actual Gun
build a body drill holes to run wires
add a barrel to insert the coil in to
add a button as a trigger
add diode if desired
Step 4: Final Thoughts
it only fires less than a foot.
giving it more than 12 v frys it
and it has a chance of shooting the round back at you( i added plastic shield to deflect the round to the side to eject like a casing.)
