Introduction: Complete Pure Sinewave Inverter
complete pure sinewave inverter
Step 1: Introduction
The inverter PCB is easy to assemble by following the label of the components to be inserted. The choice of the voltage to be used to power the inverter ranging from 12v to 96v depends on kva you are designing. for any setup, a 12v relay is to be use. The featuring M.C.U are the Microchip PIC16F72A and PIC16F876AFEATURES OF THE ABOVE SCHEMATIC ARE STATED BELOW :
INVERTER PROTECTION : LOW-BATTERY SHUTDOWN : OVER LOAD SHUTDOWN INPUT : O/P SHORT CCT SHUT-DOWN INPUT : HIGH TEMPERATURE SHUT-DOWN INPUT : LOW-BATTERY : BEEP START AT 11 V :INVERTER SHUT DOWN AT 10.5 V :10 SEC DELAY BEFORE CHARGING : AUTOMATIC VOLTAGE REGULATOR [INPUT: 180 V - 240 V] [OUTPUT: 211 V - 232 V] INVERTER MONITOR : 16*2 LCD DISPLAY : LED INDICATORS : ERROR LED : BUZZER
Step 2: Proteus and Simulation
Step 3: INTERTING OF COMPONENT
Step 4: ASSEMBLING
Step 5: Charging
Step 6: Finishing
Step 7: Packaging of Mother Board
For the pure sinewave inverter circuit, pcb, video and code, pls, visit acecct.blogspot.com or whatz app me on : +2348123206299
