Introduction: Cornhole
my cornhole boards
Step 1: Cutting the Dimensions
I used 3/4 in plywood
cut the ply wood at 2ft for the width and the length was 42in
I used 2/4 for the frame
cut 4 2ft pieces for the width of each board
then I cut the length of the support boards at 39in
Step 2: Put the Boards Together
glue and screw the 2ft board and the 39in boards to the plywood
Step 3: Sanding
there were cracks and some holes in my board so I used wood filler to fill them in
let that dry for a day or so then sand it down and if there's still holes keep filling them so its flat and smooth and then do another sanding job so its completely smooth
Step 4: Drill the Hole
I used a fly cutter to drill my 6in hole
take a drill and measure the diameter and then find the radius of the hole to put the drill to drill the hole
Step 5: Legs
we kept cutting and measured till we found out the right height
the boards need to sit a foot off of the ground so u have to had the angle into the equation so it will sit level on the ground
Step 6: Finishing Product
that is what the finishing product should look like but I painted mine but you can doc whatever you want with them
