Custom Belt Buckles
Intro: Custom Belt Buckles
This project uses store bought untreated leather belt straps along with buckle blanks and shows you some methods on how to get creative and make your own custom belts. Making your own is easy! All of the supplies you need can easily be found at craft stores, leather supplies wholesaler or the internet.
This project covers how to make resin-embedded belt buckle inserts and how to treat and finish a leather belt.
Enough talk, let's make some belts!
STEP 1: Tools + Materials
- small disposable mixing containers
- stir sticks
- latex gloves
- colour printer + paper
- photo editing software
- scissors
. materials:
- belt buckle blanks*
- belt buckle insert (for size reference)*
- cow hide leather belts*
- neatsfoot oil*
- newspaper
- casting resin%
* http://www.tandyleatherfactory.com
% http://www.michaels.com/ .
STEP 2: Embellishments & Cut-outs
For these belts I decided to try 2 different types of buckles: embellishments embedded in the resin, and custom colour printouts.
Embellishments
Since fall produces some great colours, I thought it would be fun to make a collage from small press-dried leaves. Locate leaves of your choice, I suggest gathering and pressing more than you need so you have extra. Press leaves between the pages of a heavy book for a few days, this will dry the leaves and flatten them preparing them to be added to your buckle inset.
A small pressed leaf was used as the center of my Canadian flag design, the side borders were made by cutting similar coloured leaves to the right shape. The leaves were then laid onto thick white cardstock, ready for casting resin.
Cut-outs:
For the other buckles I decided to make custom colour images. These belts were destined to be gifts, so I used images that would be meaningful to the recipients. In this case: John Wayne and the metal band Slayer (not for the same person). I found a few classic John Wayne images online, and decided to settle on the iconic black and white movie still from True Grit. The Slayer image is also a classic and your Slayer buckle may turn out better if you're listening to Reign In Blood, just sayin'.
The images were imported to a photo editing program and resized to be slightly larger than the measured inset of the buckle. Then the images were printed on white printer paper. Each icon was cut out using the leather blank as a guide, this ensured that each image cut out is exactly the right size to fit into the inset.
STEP 3: Resin
Warning: Most casting resins come in a 2-part solution, the resin and a hardener. When mixed, the two produce a chemical reaction and begin solidifying (curing). This process takes about 24 hours to set fully, but you can see a drastic change in viscosity within the first 30 minutes. During the curing the resin is exothemic, meaning it produces heat, this isn't much of a concern with the volume used in this project but caution should be used when casting anything over 25mm (1") thick. The the resin can heat up considerably and cause fractures in the resin while drying. For larger/deeper casts it's advised to pour in stages to avoid any issues with overheating your resin.
The type of resin used here is commonly available EasyCast casting epoxy. The bottles were heated in warm water for a few minutes, then the resin and the hardener were measured out in separate exact quantities, then combined and mixed thouroughly for 2 minutes. After, the mixture needed to be transferred into a new clean container and mixed again with a new stir stick for another 2 minutes.
Using the stir stick a small amount of epoxy was applied to the bare face of the buckle blank, giving the colour print image something to adhere to before embedding with resin. When image or embellishments have been placed on buckle blank gently pour mixed casting resin over entire buckle insert. Since this buckle was slightly curved, and I anticipated the resin might gather at the edges and overflow, the resin was only filled about halfway up the insert.
You can gently poke through the resin to adjust the image or embellishments, but after about 40 minutes the resin begins to get set and any poking/touching of the resin will mar the smooth finish. You've been warned.
Lie buckles is a flat position, leave buckles to cure overnight at room temperature.
STEP 4: Oil Leather
First gently brush each raw belt to remove any foreign material. Then, using a cloth spread the oil over the entire belt on all sides and leave in the sun for a few hours. Repeat the process with a second coat.
Your belt is now treated and is ready to be used, use any extra oil for yearly applications and keep your belt strong and flexible.
STEP 5: Finish Belt
My belt came with buttons to secure the buckle, so I just had to cut a taper in the end and drill the belt notches.
Taper:
If you don't have an old belt to use as a reference then trace your taper onto a sheet of paper to get a symmetrical shape you are satisfied with, then cut out that shape and trace onto end of belt. Use a
Notch holes:
Drill notch holes by using an old belt as a template, or spacing your notches roughly 12mm (0.5").
Stamping:
You can choose to leave your belts plain, or you can emboss the leather. I used the tip of Phillips-head screwdriver hammered into the leather to make some neat imprints, then I embossed a shell casing into one of the belts for my gun-enthusiast friend.
STEP 6:
All that's left is to attach the buckles to the belts and you're ready to show off your new custom belt.
If you find that your embellishments have poked through the resin as it was curing. You can easily pour a new layer of resin over the existing resin after it has dried and cover any exposed embellishments, just repeat all the steps with a fresh batch of mixed resin.
Lookin' good there, cowboy!
Have you made your own version of this project, or cast something else with casting resin based on this project? Post a photo of your results in the comments below.
Happy making :)
28 Comments
jeanniesbttl 8 months ago
tejer 8 years ago
Hi, how did you make the leather blank for cutting out the images? My blanks have rounded corners, I'm spending way to much time trying to make to cuts perfect. Also, what program did you use for sizing?
mikeasaurus 8 years ago
Any photo editing software will work for sizing. Step 2 covers how I made the images fit inside the rounded buckle blanks.
trydanearl 9 years ago
Do you use photo paper for your images? Do you coat them with anything before you put on the clear casting?
mikeasaurus 9 years ago
I used regular printer paper. The resin did dull the colour a bit, so photo paper is probably a better choice.
EthanJP 10 years ago
sunshiine 12 years ago
Sunshiine
sunshiine 10 years ago
sunshiine
3366carlos 11 years ago
akkunth 11 years ago
mikeasaurus 11 years ago
I'd love to see your results!
OnTheRange 11 years ago
Do you know if you can do multiple layers of the epoxy???
I was thinking of using an Altoid tin and making a scene with cutouts that has some depth....Like an eagle in the foreground mountains in the background and clouds on top of them? Just wondering
pdub77 11 years ago
imbigman 11 years ago
FlatLinerMEDIC 12 years ago
mikeasaurus 12 years ago
Maker-Breaker 12 years ago
I
m going to check out your stuff on dollar store crafts.
To emboss, I used something that had engraving in it which would transfer onto the soft leather when pressure is applied.
For the example shown here, I used an old shotgun shell cartridge which has the manufacturer and type of shell engraved on the brass backside. The brass backing was placed face down on the leather, then the two were clamped together on a vise and left overnight. Almost any engraved object should work, but test out on scrap leather first to make sure.
