Dodge Luge 100% Homemade
Intro: Dodge Luge 100% Homemade
very dogg this luge is made of sh*t that i had in my garage and other sh*t i had built before
STEP 1: Tools and Materials
TOOLS
1. Hammer
2. skrew driver (4 wat ever kind of skrews you have)
3. drilling machine (electric is way easer)
4. drill bits for the skrews
5. ruler of tape measure
6. pencil
MATERIALS
1. a plank longer than your body (the thicker the better)
2. old skateboard
3. wood board (i used old cuboard doors)
4. other planks for reinforcing (if your first plank is to thin)
5. steel angle or other steel for reinforcing the first plank
6. wat ever skrews and nails you can find
1. Hammer
6. pencil
MATERIALS
2. old skateboard
STEP 2: The Wheel Base
i skrewed the trucks onto the long plank to form the wheel base and give me the main boby of my luge.
i also discovered that the long plank was to flexable.
STEP 3: The Seat and Foot Rest
now climb onto the luge and figure out where you are most comfortable. my foot rest was about 4 inches from the front. now find were your a*s goes and locate the board there. place a brick under were you are going 2 skrew the board down.
because of the truck being located were it is i had 2 make a T shape with the footrest to skrew it down.
i put a skrew about every 20-25cm apart.
STEP 4: Back Rest
the back rest that i made was made from a plank that i used for reinforcing that by luck it had a block on it and i used it to raise the back rest.
STEP 5: Reinforce the Wheelbase
her is where i used the steel.
i used two peaces that we had removed from our ceiling long ago and stored in the roof of our garage.
i lined up the holes as best as possible and used coach bolts to fasten them down(up) .
STEP 6: The Parachute
this is an ad-on for if want to stop and the box is a good head rest.i skrewed the box down and inserted the kite and bar ib there places.
i used a 8square meter kite that i made and it did not work will (as a kite ) for the parachute. i used the bar for a spreader bar out the back of the luge to make the kite open. and the deployment device is a simple sain netting adaption. the one side of the parachute pulles out first then the other side pulles tight in the wind and stops you. mine weighed 21.5 kgs
STEP 7: Da End
REMEMBER TO USE YOUR IMAGINATION AND IMPREVISE AND HAVE FUN
HAVE FUN AND BE SAFE
9 Comments
ilpug 12 years ago
saxophones 14 years ago
freeza36 12 years ago
mastermakoko 15 years ago
killerjackalope 15 years ago
So for a start turn the caps lock off for that last step, use the spell checker and avoid using text language or 1337 speak...
Your pictures are pretty decent which is good because that's where people usually have problems...
I added a few keywords to help people find your instructable.
I'd also suggest re-writing the intro to the 'ible
zjharva 15 years ago
Remember staff-ish thing, part of duties...
We've had this conversation before... When you saw the featuring...
