Introduction: Automatic/manual Drip Irrigation
got ideas from
https://www.instructables.com/id/Arduino-water-syst...
Step 1: Materials Required
main items:
1. pipes //choose two different sizes of pipe as u require.
2. pump
3. power supply ,( can be battery,adapter...)
4. switch for on and off
tools:
• cutter
• screwdriver
• tape
making it automatic just require a microcontroller
• i have used arduino mega 2560
Step 2: Making Stand
cutting the long pipe in small one as shown in the pic above
Step 3: Making Hole in the Stand for Small Pipe
making a hole in the pipe so that small pipe can be inserted and fixed into the ground.
Step 4: Connection
make the hole in the long pipe and connect it to small pipe..
Step 5: Pump
close the other end of the pipe..
you just need to connect a pump to the end of the pipe and connect it to a power source................
this is only for manual process
Step 6: Making It Automatic
for this you require a micro controller
and an 5v pump or u can purchase 12v and add a relay..
upload the code to arduino and see the comments of the code for connections
code
click the link which is above
or
http://pastebin.com/jGJsD82n // copy this and paste in search engine
details of making it automatic is written in the code itself.......
Step 7: Please Vote
the vote button is at top right side of the page
