(easily) Etch Images in Copper
243,495
404
111
Introduction: (easily) Etch Images in Copper
About: the adventure continues
Make a copper etching of any image. This takes about 1 hour, including image prep, transfer, and etching, and it works really well. Check it out!
http://www.artiswrong.com
Step 1: Overview
I was making PCBs today (using vincent's excellent 5PCB instructable!), and they were coming out really well. I thought I might try images, and after a bit of trial and error, I got that working well, too.
This instructable will leave you with a nice copper etching of a digital image of your choice.
Along the way, you will:
Do some digital image editing and manipulation
Laser print your image onto a transparency
Iron the transparency onto a copper clad board
Chemically etch the board
Ready? Onwards!
Step 2: Get Yo' Materials Together
You'll need:
Some circuit board etchant (FeCl2)
A copper clad board the size of your image
A transparency (kinko's sells them for about $1)
A laser printer
An iron
A plastic tray larger than your board (to hold the board and etchant)
Step 3: Get Some Tunes
Before you begin your labor, you'll need (for your own safety) some smooth jams to rock out to.
Slip a favorite CD into that deck of yours, or grab one of my mixes from http://www.artiswrong.com/alex/mix
Now you're ready to get down to it!
Step 4: Prepare Your Image
So, pick an image you'd like to etch. In general, you'll want something with high contrast, since , while grayscale will etch, greater contrast looks better. I used a sillhouette picture of me, and it turned out well.
OK, so using your favorite image editor, convert the image colors to grayscale. This will give you a better idea of what the image will look like once it's etched.
Now, scale the image so that it'll print to a fairly small area. Mine were 3"x4", and they worked out alright. I tried a full page image, and it's really hard to get the transfer to work for larger images. Try something small to start out with.
Remember that the image will be flipped (mirrored) when you transfer it, so you might want to flip the image before you print it (and definitely flip any text).
Print the image onto a normal sheet of paper and see how you like it. Play around with it until you're happy. Then, move on to the next step.
You might notice that I made 4 small images. Play around with it! Try inverting the colors, or playing with the contrast/brightness settings
Step 5: Print Onto the Transparency
**WARNING--You are about to put a plastic transparency into your laser printer. I've done this a bunch and haven't had any trouble (I have a HP laserjet 1200), but you should be aware that your printer has a very hot fuser and you are going to put plastic through it. I've never heard of anyone having any trouble, but I just want to mention it here. Are you done ignoring my warning? Cool--let's go on**
Load a transparency into your printer's tray.
Print your image exactly as you did before. Remember which side of the transparency your ink is on. Maybe mark it. If your image has text, this isn't a big deal--you'll just put it onto the copper so that the text (which you printed backwards, remember) looks correct (like normal text).
Step 6: Transfer the Ink Onto the Copper
Now you want to transfer the transparency onto your copper sheet.
First, you want to take a piece of steel wool to the copper sheet (both sides), and buff it until the entire sheet is shiny.
If your transparency is much larger than the copper sheet, you can trim it down, but leave some (.5 inch) room on the sides of the image.
Now, plug in your iron, and set it to a hot setting.
Put your copper board down on the ironing board. Position the transparency over it(ink side facing the board!). Put a piece of wax paper over the transparency.
Now, being careful not to slide the transparency around, put the iron on top of the wax paper. Press down with the iron, and iron all around the transparency . Iron for about 5 minutes--if you iron for less, the ink won't transfer well and you'll have to do it over again.
When you're done, set the iron to the side. The copper boards will be very hot!
I found that the ink will transfer best when the board cools down. You could either wait for ~10 minutes, or, if you're impatient like me, you can carry the board to a sink (remember that it's really hot!), and run some cold water over the other side of the board. This will cool the board down in about 10 seconds.
After the board is cool, peel back the transparency. Most of the ink should have transfered to the copper board. If you notice that it only partially transferred, it's OK. Leave the transparency on the board, put the wax paper on it again, and iron some more.
When you see a pretty faithful representation on your board of your image, you're done. Onwards!
Step 7: Etch-yer-sketch!
Now you'll use ferric chloride to etch away your copper and "develop" your boards
First, you should know that ferric chloride is really messy and can stain stuff (like floors!), so do this in an 'informal' setting. Ferric chloride is also acidic, so you'll want some nitrile gloves. I've had some on my skin, and it just irritates, rather than burning through my body, but it's not a nice sensation. Safety glasses might also be a good idea for the safety-conscious instructable
So, put down a plastic pan that's larger than your copper board. You want a nice, heavy-duty plastic like a container lid.
Put your copper board face down in the pan. Slowly pour ferric chloride over the board until the board is submerged.
Now, you sit back and wait. It took me about 30 minutes to fully etch my boards. Check in on your boards every so often to see how well the copper's etching.
When it's etched to your satisfaction (you should only see the black ink of your image, and the fiberglass board everywhere else), pull the board out and clean it off with water. Be sure to rinse off all the etchant. Remember that even a little bit of etchant can stain a porcelain sink, so do this somewhere 'informal' I sponged mine off first with paper towels, and that made things less messy.
Hang on to your etchant--you can do a bunch of boards before it'll stop working. When you do want to get rid of it, DON'T pour it down your drains.
MGchemicals.com offers this advice for disposing of Ferric Chloride:
1. Contact your local Hazardous Waste Disposal Company
2. The solution must not be put down the drain because of residual copper ions left in it. To make it safe for disposal, you can add sodium carbonate (washing soda) or sodium hydroxide to it to neutralize it, until the pH value goes up to between 7.0 and 8.0, testing it with indicator paper. Copper will be deposited as a sludge. Allow the sludge to settle, pour off the liquid, further dilute it with water and then it can be poured down the drain. Collect the sludge in plastic bags and dispose of it as required by your local waste authority.
If you're at a university, just contact your Environmental and Health Safety Office, and they'll be happy to collect it and dispose of it properly.
Step 8: Finish Up
Take some steel wool and go over your board. The blank ink should come off easily and you'll have shiny copper underneath. With any luck, your boards should come out nicely. If your board was larger than your image, you can trim it down with a paper cutter (although the fiberglass board will dull the blade)
Step 9: Cheese-it!
Cool, you're done!
Enjoy your cool etchings. I'm making two-sided etchings to use as my business cards. Now go out and do some cool stuff!
-al
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    111 Comments
    StacyP2
    StacyP2
    7 years ago on Step 7
    Hey,
    I am trying to make a fountain with a large piece of copper art as the surface that the water cascades over. Do you know if I can use this etching process and have the image remain in tact after extended water exposure?
    Thanks
    anotherspecialedmom
    anotherspecialedmom
    Reply 3 years ago
    To have the image remain intact, you will need to use some sort of preservative on the copper to prevent wear. You will also need to ensure the etching is very deep.
    anotherspecialedmom
    anotherspecialedmom
    Tip 3 years ago on Step 7
    To dispose of the acid, carefully add baking soda to it, mixing with your gloved hands until you have a solid-like mass. It should be the consistency of potting soil. When there is no liquid left, your ph will be neutral and you will be able to dispose of the waste in the regular garbage.
    NoaP1
    NoaP1
    6 years ago
    is this good for printing? WHat is thickness os plate?
    DangerousTim
    DangerousTim
    6 years ago
    Using halftone effect with lines turns out much better
    ahartitzsch
    ahartitzsch
    8 years ago on Introduction
    Great post! I have started having a go but am having issues with getting the tone transfer onto the copper. Parts of the toner transfers but not all of it. I have made sure my coppers extra clean and used an iron on it for a long time. Any suggestions on getting a clean and full transfer?
    Jack Corsair
    Jack Corsair
    one thing my brother did was reprint on top of his old print twice. so you get more ink that can transfer.
    iamaqtpoo
    iamaqtpoo
    12 years ago on Introduction
    Can you use this technique on other metals? I am just starting and would prefer to mess up on cheaper metal 1st..ha! Thanks for the great, cheap, user friendly guide!
    sprive
    sprive
    Reply 11 years ago on Introduction
    What @dagenius said. A 6 inch by 4 inch piece of FR4 is about $2 on ebay. You might need to order 2 or 4 pieces to get free shipping.
    For photos, the thinnest board works best, and is easily cut with a razor blade and edge, or paper cutter.
    The fiberglass backing could be any color, unfortunately. Some very thin (flexible) PR4 I ordered had solid black backing, which is perfect for photos. Just remember that you will have 2 "colors" - copper, and the background. In some cases you may want to invert the picture and slightly alter the color "levels" to maximize desired detail.
    Thicker PR4 might not fit in some picture frames, but if you shop based on cost it's not likely you would end up buying the thicker circuit board stuff (as weighter stuff is more expensive).
    The iron transfer worked awesome. This valentines day my wife gets a hand-made card which could be framed. :-)
    MatanSilver
    MatanSilver
    Reply 12 years ago on Introduction
    The copper is actually plating on a material called FR4, which is fiber glass. The boards themselves can be bought cheaply from electronics suppliers like radioshack, digikey.com, etc...
    WingDings
    WingDings
    11 years ago on Step 3
    I followed the link to your site, but got a warning that there were viruses/trojans/exploits on (at least) one of the pages. Might be worth cleaning up? Unless of course it’s your intent to infect people’s computers, in which case, carry on!
    syrax
    syrax
    13 years ago on Introduction
    it's not the best solution :) i make this similar but .... when convert image to B/W i save it in WBMP in photoshop, this give me a very small Black and White pixels NO GRAYSCALE , after that just convert this WBMP to normal BMP and it's ready to "print" . When you use grayscale it's hard to etch Regards from Bulgaria
    sprive
    sprive
    +1 to this comment here, folks.
    If you are etching, you only have 2 "colors": copper and substrate. There is no ability to blend or gradient the colors except by dithering/halftones. So you must use black and white, for best effect.
    Also note with B&W, there are a range of dithering and halftone options you can choose from, which affect both the coarseness of the dots (think: newspaper halftones) and the placement of the dots (in a regular grid, or gridless which makes the dots look more randomly placed, like old Macintosh artwork).
    As a constructive suggestion, @syrax's b&w photo looks a little washed out in the highlights. That's not due to his b&w method, but rather the original photo -is- actually washed out in the foreground. This could be fixed by playing around with the Levels or Gamma in Gimp or Photoshop, and that would restore some facial detail that's currently lost in a large area free of any detail (white).
    I'm about to attempt this, to take up extra space on a PCB, for my first etch. :-)
    HMBeck
    HMBeck
    It looks like a curb. In the background there is a man-hole cover. All I don't understand is where the banana is?
    vincent7520
    vincent7520
    12 years ago on Step 3
    On what do these beautiful apples rest ?…
    It looks like an old sink that we had in our farms here way back then …
    Am I wrong ?
    Note, for the funny side ot things : at 1st I thought they were resting on the curb of a side walk. Curbs in most French cities (from where I post) are made from the same stone, with water runnig at the base it made the whole thing real. But who would put apples there ???… :D
    eclarep
    eclarep
    13 years ago on Step 8
    Great art! I'm going to try it with some very thin copper tags I found.
    As an Art Major (who is planning on going to medical school, completely abandoning art for the time being), I focused on printmaking.
    To clean the plate without damaging it (steel wool seems harsh) I always used cheesecloth with a bit of mineral spirits.  It works really well if you are using lithograph inks.
    Also, you can find genuine copper plates at art supply stores.  They are expensive! In fact, I split the cost of one with 3 classmates during my last semester of college (Spring 08) and haven't used it yet. Fear of commitment/not wanting to ruin something so expensive led me to re-use the plates people had discarded, even when no copper was left.
    MatanSilver
    MatanSilver
    These aren't really copper plates. They are copper plated fiberglass
    StuNutt
    StuNutt
    12 years ago on Step 9
    Thanks Man,
    I've started doing a few printed circuit boards and been having some problems, but there's ideas in here that have helped.
    Stu
    -Aj-
    -Aj-
    would a bubble jet printer work? or does it need to be laser due to the different ink?
    beehard44
    beehard44
    bubble jets have special transparencies. Just for the info of others, i read your post in reply to the post i am currently replying on...
