Introduction: Easy Mini Greenhouse
This is an easy indoor mini seed starting hut.
Step 1: Materials:
plastic wrap
cardboard box
shoebox
trash bag
clear large bag
hot glue gun
chopsticks
Step 2: Cut Flaps Off Box and Start Frame
  1. cut the side flaps off the box
  2. look inside your cardboard and there are small cavities toy can put you chopsticks into. slip your chopsticks into every side
  3. glue down each chopstick so it is sturdy
Step 3:
Step 4: Frame Continued...
  1. glue two chopsticks together and lay them across the top of the frame
  2. glue the chopsticks firmly on to the frame
Step 5: Add the Cover and Sides
  1. put the plastic wrap on all sides except for one
  2. Put plastic(non plastic wrap version) on the side that is not covered
  3. glue the plastic to the top chopstick
Step 6:
Step 7: Move Inside Short Side Flaps
  1. move the short flaps up and glue it to the side of the box
Step 8: Open Up the Inside Flaps
  1. If there is packaging tape cut through it
  2. pull down the flaps on the bottom
Step 9: Take Out the Shoebox
  1. pull apart the shoebox
  2. measure or eyeball the length and width of the bottom of your box
  3. measure the same amount and cut out
  4. make slits in that piece of cardboard
Step 10:
Step 11: Cut Out Another Piece
  1. cut out another piece of the same width but larger length
  2. remove the pull tight thing from trash bag
  3. cover that piece with the trash bag
Step 12: Finishing
attach at a diagonal slant and make sure one side touches 2 bottom corners and one side touches two top corners. glue all sides of the plastic piece to the greenhouse
VIOLA YOU MADE A mini indoor GREENHOUSE!!!!
Step 13: A Look at My Plants
swiss chard
snow peas
tomato sprout
thyme sprout(can't see in picture)
sage sprout (can't see in picture)
