Introduction: Elevation Elements
now elevation is down here are some instructions for elements.
video with all this stuff and more is here:
Step 1: The Bowl
the ball needs some speed before entering the bowl.
Step 2: Halfpipe Thing
this is the halfpipe. it's actually shadowman's tunnel from cataclysm. (last two pics)
Step 3: Maze
this is the most piece unfriendly element i ever made, however it's cool
the orange connectors are obstacles.j
Step 4: Very Well Working Halfpipe
THIS IS HARD TO MAKE IT WORK PERFECT!!
but then it is very cool :)
Step 5: Bounce Element
this is just for fun. make sure you keep it level
Step 6: Pathing
this is a new kind of pathing, you can make it straight (2) or curved (3)
Step 7: Arm With Stop
this is a special arm because the ball will roll to the yellow rod, which lets the arm move.
Step 8: Path With Elastic Edges
it works the best when the ball has some speed when it enters.
Step 9: Zigzag Stairs
this is the zigzag stairs. note that the supports are a little strange to connect. (last 2 pics)
Step 10: Tire Tube
this is an element that's originally made by knextreme.
Step 11: Gap Element
this is a variation on my gap element from flashback. the ball rolls half a circle, and then it falls onto the next.
Step 12: 2 Railed Path Adds
when the ball rolls the adds move
Step 13: Zigzag Path
Step 14: Flat Spiral V2
this is a new version of kairah's flat spiral.
Step 15: Alternators
Step 16: 2 Ball Turner
the first ball arrives and stops at the end of the track. when the second ball comes, the track will move and both balls will leave.
member Happy999 edited this so it will turn if there is only one ball. the last three pictures shows her design.
