Introduction: Fake Brass Knuckles
use a foam egg carton masking tape and paint to make cool display brass knuckles
Step 1: Materials
materials
-foam egg carton
-glue
-tape
-(optional) painters tape
outer part 1
-painters tape
-silver paint
outer part 2
-spray glue
-tin foil
-foam egg carton
-glue
-tape
outer part 1
-painters tape
-silver paint
outer part 2
-spray glue
-tin foil
Step 2: Pix
find an internet picture or use mine
adjust size to fit your hand
then print
then print
Step 3: Trace
cut out your template then
trace it onto the foam
Step 4: Cut
cut the outline out
repeat 3 to 4 times
repeat 3 to 4 times
Step 5: Glue
glue them together then tape them so they will dry properly
Step 6: Trim
trim so they are even
Step 7: Covering 1
tape edges with painters tape then spray paint silver
Step 8: Covering 2
spray with spray glue then add tin foil to give it a metal finish
Step 9: Ta Da
you are done
