Introduction: Flashlight E Cig Hack
how to easily turn your $0.99 flashlight into a $200 e cig and start vaping in no time. I can honestly say that this mod works just as good as any $200 top shelf vaporizer. have fun stay vaped! this mod will work with waxes and oils as well
Step 1: Dismember Old E Cig
take apart any of your old ecigs so you can get the 510 connector. you won't need anything but the top piece that screws that atomizer or clearomizer on, you can take the button and everything else out. you won't need anything so you can save the battery for later use and toss the other stuff
Step 2: Gut the Flashlight
take everything out of the flashlight including the plastic cover the lens the light everything
Step 3: Get Connected
the outside of the 510 connector is negative and the middle piece is positive. if the wire ripped off the middle piece you can pop out the middle by poking the bottom and connect or solder a new wire for the positive lead. I have a nother mod where I just stuck a washer to the 510 connector so it would fit in the flashlight. the body of the flashlight is the negative. you will have to connect a spring to the wire in middle of connector for positive
Step 4: Finish Up
you can now epoxy the extra space between the flashlight and connector make sure the positive doesn't touch them - and you have everything correct. you can get an 18650 battery and it will fit perfect in the flashlight giving it the clouds of a thousand dollar hookah. enjoy!
