Introduction: Flower Bracelet
How to create a beautiful flower bracelet
Step 1: What You'll Need
1.Two pieces of wire to fit your hand
2. Perls blue, black and transparent
3.Six circles of jewelry
4.A brooch of any kind
5. Pliers to cut bend and squeeze
6. Nylon thread of 6lb
Step 2: Corner Bend
we take the wires and in a corner bend drawing a circle
Step 3: Insert a Black Pearl
Insert a black pearl and deliver at the other end, do this with the two pieces of wire
Step 4: Then Insert a Piece of Nylon Two Transparent
Then insert a piece of nylon two transparent beads and nylon carry the center and the right end of the nylon insert it into the black pearl right and left toe left the Black Pearl
Step 5: Then Each Nylon Tip
Then each nylon tip only we put a blue pearl
Step 6: Insert Pearl Transparent
Then we take the two ends of the nylon and getting a pearl cross transparent
Step 7: Insert a Blue Pearl
insert a blue pearl on each end of the nylon
Step 8: Then Inserted Into Each End of the Nylon
Then inserted into each end of the nylon and wire a black pearl
Step 9: We Continue the Process ....
we continue the process until you reach the tip of the other side
and we do the same fold start
Step 10: Then Each Fold We Made Him a Little Circle of Jewelry
Then each fold we made him a little circle of jewelry inserted on each side and then join with another small circle by the two previous two as a triangle
Step 11: Finally!
Finally put a pin between the two circles in each corner
Step 12: And Finish
The end
