Folded Cardboard Window Blind
Intro: Folded Cardboard Window Blind
I live in northern Sweden, and in summer - there's no sunset it never gets dark.
Our house has many big windows and I'm simply too cheap to buy that much window blinds :P
I came up with this inexpensive, easy and yet decorative window blind.
It takes about 30 minutes to make one.
STEP 1: Materials
You'll need:
a big sheet of cardboard (the one i used was kind of sloppy and had a lot of holes in it - you may choose a nicer one)
drill
some twine
a long straight piece of lumber or anything else - it has to be straight thats all, you'll only need it as help for cutting)
a knive or cutter
2 hairclips or clothespins
2 hooks or heavy stones
1 big needle for the twine (works without but it'll much easier with the needle)
drill
some twine
a knive or cutter
STEP 2: Measure Your Window
measure your window, and add about 20inches to the height.
cut your cardboard the same size.
you'll need to know the depth as well.
STEP 3: Impress the Cardboard :)
you measured the depth of your window - right?
let' say it is 5 inches deep, than you'll make your foldes about 2,5 inches.
mark lines with for example 2,5 inches distance,
take the straight piece of lumber (or whatever you use) and place it on the cardboard.
now takte the BACK of your knife or cutter and impress every second line,
DON'T CUT THROUGH the card board, the lines are only a help for folding the blind. you won't need much pressure.
See the pictures.
See the pictures.
STEP 4: Folding
no fold the cardboard in every line - all in the same direction!
press the fold hard with your hand.
see the pictures
Now turn the sheet around.
see the pictures
STEP 5: Impress Other Side
now impress the remaining lines on the other side, and fold them too.
you'll end up with a zig-zag folded cardboard.
STEP 6: Drill a Hole and Thread It
now take your drill and drill a hole through the folded blind.
take the twine and thread it through the holes.
if you have a big needle, life will be much easier ;)
make a knot on one end, (see the pictures)
Now repeat this on the other side.
STEP 7: Mount the Blind
mount the side with the knot, on the upside of your window.
i chose too clamp it between the window an the frame, for a more permanent solution, you may use skrews.
tense the both twines on the bottom of the window, i used two heavy stones, for a more permanent solution use hooks.
STEP 8: Adjust Length
to adjust the lenght of the window blind, use the hairclips or clothingpins as shown in the pictures.
69 Comments
Grand MasterP 7 years ago
do fluorescent paperboard catch fire from sun heat?
need expert help.
Uncle Kudzu 12 years ago
I have a street/security light problem that this fine instructable could help with. I like the cardboard look, but others are already coming up with ideas to modify the look. One can imagine a block print or stencil scheme before scoring the folds...
FreyaSykes 8 years ago
Same here and it is setting off my son's epilepsy as his trigger is sleep deprivation so I'm going to give this a try to see if it solves the problem! Thank you for this!
BtheBike 12 years ago
Also a reuse jacket Cord Stopper to hold it in place.
Great Ible !
aristide202 11 years ago
jacq01uk 12 years ago
:o)
Mimikry 12 years ago
I'm trying to improve the look and function.
I thought about very strong Velcro to mount the blinds to the frame, without drilling holes.
jjhafford 10 years ago
Mimikry 11 years ago
I think the "airpockets" in cardboard should be helpful for insulation, but I'm not sure how much effect it really has :)
thewmas 12 years ago
SIRJAMES09 12 years ago
aie_i 11 years ago
danlynne07 11 years ago
mahvin 12 years ago
You can use most any kind of material, just make sure it's stiff...or starch it untill it is stiff.
I used wallpaper to make mine. If you use wallpaper, make sure that it does not have glue on it or that it is NOT pre-pasted(comes with glue already on it) or it just might end up sticking to your windows or walls.
That was my first mistake using wall paper. LOL
TY again for sharing.
i've never seen pre-pasted ones in Sweden but i'll think on it when i buy some :)
Great recycling ;o)
