Introduction: Hairband Bracelet
Hi! this is a bracelet made from a dozen or so hairbands. This takes only 5 minutes to make.
Step 1:
First take a band and keep it between your thumb and the index finger. The first band should be in the shape of '8'.
The second band should be kept normally(only the first band should be kept in the shape of '8'). Then pull the end of the first band and release it over your finger. Do this for both the ends. Then add another band and repeat the process.
Step 2:
Repeat the process till you get a long bracelet. Connect the ends of the bracelet using a clip. You can add or remove bands to adjust its length.
