Introduction: Headphone Hat !
some month ago i broke the bow of my headphones. I thought it would be a good idea to keep the headphones, because I might use them some other time.
I usually used to wear a hat under my headphones, so i had the idea to make my own "headphone hat".
In order to build that headphone hat yourself, you will need the following material:
first of all, you will need
a hat with douple layers
headphones (I used the Sony clip headphones)
scissors
lighter- but- only if you have a hat made of synthetic textile, otherwise, if you have a cotton-made hat, you will need needle and thread
paper and pencil to make a mask
a screwdriver
scissors
a screwdriver
Step 1: Deconstruct Headphones
-get rid of the bow and the ear cushions (for that you will not need any tools)
-remove the screws
-remove the screws
Step 2: Make a Mask
-blueprint the form of the inner parts of the speaker (distinguish between the left and the right one)
-cut them out
-cut them out
Step 3: Cuting Holes in the Hat
-put the hat on and mark the spots on the hat where the headphones are gonna be placed
-put the mask of the inner parts on the marked spots of the hat and with the help of a pencil, circle around the mask
-cut out the marked spots on the outer layer of the hat only and keep in mind that the hat material might strech out (so you rather make it a little smaller than mask)
Step 4: Seal the Egdes of the Holes
seal the egdes of the holes
-burn the egdes of the holes in order to prevent the unraveling of the textile
-in case you have cotton hat sew the egdes
Step 5: Install the Headphones
install the headphones
- put the inner side of the headphone in the hole
-put the two parts of the headphone together
-fasten the srews from the inside of the hat
this is the way i built my headphone hat. this is just one possibility to do that. feel free to make you own experiment.
By the way, headphone hats rock!!!
