Introduction: Heatsinking Leds by Recycling Old Transformers
hi
in this tutorial i will show you how to recycle old transformers into led cooler
first :why cooling an led ,if you worked with power led before there is something you must know ,unlike normal small led which doesn't produce any heat (warm)
power led (1watt or more) produce's alot of heat if it ran at the maximum power in a previous instructable i made a 1 watt flashlight using 2 AA batteries , the maximum voltage for an led is 4.1 v , (2×1.5=3) so the led ran at a lower voltage ,in this instructable the led will run at 3.7-4.0 v (li-ion)
tip:the cooler the led was the brighter it will be ,lower temperature=longer lifespan
instagram.com/hamza_M.G
twitter.com/hamza_elgendy
follow =follow back
follow =follow back
Step 1: What You'll Need
you will need
1:an old transformer
2:thermal compound
3:electrical tape
4: 4×zip ties
5:power led
2:thermal compound
3:electrical tape
4: 4×zip ties
5:power led
Step 2: Dismantling the Transformer
how to dismantle the transformer
1:using a flat head screwdriver or a knife push up the metal peices from the marked areas
2:it will give you 2 shapes an (M) (|)
Step 3: Making the Cooler
how to assemble the cooler
1: stack five or more peices of metal ,and put a dot of thermal compound between then
2:hold them up together with a peice of electrical tape or zip ties (as seen in the picture)
Step 4: Attaching the Led
1:now connect the wires to the led as seen black(-) red(+)
2:push the two led terminals up so they don't shortout when you put them on the metal cooler
3:put some thermal compound on the led and attache it to the cooler as seen
thank you and please like an follow for more awesome projects
Step 5: Another Option
you can also use the other shape to make a heatsink
