How I Fixed My Microwave in 15 Minutes
Intro: How I Fixed My Microwave in 15 Minutes
after reading this article from hackaday i decided i should probably try and figure out why my microwave hasnt had a display for the last few years the following was my experience
legal .....microwaves have killer rabbits hiding in big black tubes these rabbits move so quickly most people blame unnecessary death on electricity used to power such devices .
do not attempt the following unless you can follow proper repair etiquette or are a trained zookeeper with a quick draw on your dart gun
also if you manage to release a killer rabbit please have you next of kin nearby to wipe you browser history (for my and your sake)
STEP 1: Dismantle
this is what my microwave was doing ...no display or random characters everything was still functional
the model is a sharp r-510ak just for posterity's sake
opening the microwave was a breese 4 screws on the back and two on either side and the cover lifted right off
STEP 2: Remove Panel
find the tab bend it out of the way pull panel up take note of wiring (take a picture or two its better ) then unplug all those connectors
STEP 3: FIX THAT
apparently this microwave was suffering from Nintendo cartridge envy as the ribbon connector was corroded
clean the contacts with a pencil eraser or denatured alcohol but never acetone.
then put it all back together
STEP 4: Results
taa daa a working display and for the record most of the fifteen minutes was trying to get the stupid cover back on ...
now i no longer have to hit the button the estimated number of minutes i want to destroy food
there are websites online trying to sell this service for $35
hopefully someone find this information useful save your electronics fix them
*(no rabbits were harmed in the making of this instructable )
4 Comments
GordonM39 7 years ago
On my Carousel MW, while two of the four back screws were Phillips head, the other two were Torx with a tamper proof center peg. Using a Dremel narrow cutting wheel, I cut slots in the screws to receive a flat head screwdriver. The control panel was mounted to the chassis with notched tabs so that the panel must be lifted to remove. Before the panel can be lifted, a Phillips screw had to be taken out. The plastic screw receiver shattered when this was attempted. A tab shattered as well. The display ribbon connector was hard-wired between the display itself and a dedicated circuit board, therefore it was irreparable, so I put the microwave back together again. I had to drill a hole through the top of the control panel and bolt the panel to the chassis in place of the broken screw receiver. A total waste of time in my case. I will continue to use the MW without a display as I have for the last decade or so.
DeborahP29 7 years ago
Any ideas? I plan on google-ing some more, I do not give up easily... sometimes it goes on a 'to-do' list until I can tackle it again.
ZacharyB16 8 years ago
Nice. Will have to give this a shot first. My display is completely dark, though the rest the functionality is there for the device
rimar2000 12 years ago
