How to Fix Shutdown Problem in Windows 10
Introduction: How to Fix Shutdown Problem in Windows 10
How to fix windows 10 shut down problem .Your PC won’t shut down after you’ve installed Windows 10. Have some problems with Shutdown. When I shutdown, my power lights remain on. Windows 10 not shutting down properly? Lights still on after shutdown? Here is the solution to your problem!. how to Fix shutdown problem in windows 10.
Microsoft has introduced the new method of shutdown, called Hybrid Shutdown. This feature is enabled by default, and it decreases the PC’s shutdown time. Hybrid Shutdown decreases the shutdown time by hibernating the kernel session, instead of completely closing it. When the PC is powered on again, the kernel session is revoked from the hibernation, so it decreases the booting time as well.
But besides increasing the performance, Hybrid Shutdown feature may also cause some errors or even prevent Windows from shutting down completely. When this happens, many computers freeze or hang when you try to shut them down, and reason for this is that Hybrid Shutdown is enabled by default. So, logically, to solve this issue, you’ll need to disable this feature. When you disable it, the kernel session won’t be hibernated on shutdown anymore, but it will be completely closed. This might increase the shutting time of your PC, but the problem will definitely be solved.
Disable Hybrid Shutdown Manually
Follow these steps to manually disabled Hybrid Shutdown feature.
1- Go to Search, type power options and click on Power Options from search results
2- On the left side of the window click on Choose what the power button does
3- If needed, click on Change settings that are currently unavailable, under Define power buttons and turn on password protection
4- From the enabled options under Shutdown settings section, uncheck Turn on fast startup (recommended) checkbox to disable Hybrid Shutdown.
5- Click Save changes button to save the modified settings. Close Power Options window when done.
This will fix: shutdown problem in windows 10 Your PC won’t shut down after you’ve installed Windows 10 problems with Shutdown windows 10 When I shutdown, my power lights remain on Lights still on after shutdown windows 10 shut down problem Windows 10 doesn't shut down properly Laptop won't shutdown completely in Windows 10
Windows 10 Shutdown Error
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • Big and Small Contest
    MilkM4
    MilkM4
    5 years ago on Introduction
    Also applies to windows 8 if you happen to be stuck with that one.
