Introduction: How to Add the Briefcase Feature in Windows 10/8
how to add the briefcase feature in windows 10/8. How to restore the missing Briefcase feature in Windows 10 / 8. the Briefcase is a special folder that supports a simple two-way file synchronization between itself and another folder. The Briefcase is designed for mobile PC users so that they may transfer it to a removable drive and have it synchronize with the computer to which the removable drive is attached.
You can use Briefcase to keep files in sync between two different computers, even if the computers aren't on the same network. If the computers aren't on the same network, you can copy files from one computer to another by using removable media, work on those files using the other computer, and then use Briefcase to sync the changes back to the original computer.
Download Briefcase Reg
https://docs.google.com/uc?id=0B1Y9NvUQRfxcUkQyWD...
To prepare Briefcase to sync:
1- Open the folder where you want to create a new Briefcase.
2- Right-click a blank area in the folder window, point to New, and then click Briefcase.
3- A new Briefcase appears. Type a name for the Briefcase, and then copy any files you want to sync into the Briefcase.
You can also create a Briefcase on your desktop by right-clicking a blank area on the desktop, pointing to New, and then clicking Briefcase.
To sync using Briefcase over a network connection
1- Copy the Briefcase over the network to the second computer.
2- Make any changes you want to the files on either computer.
3- When you are ready to sync any changes you have made, right-click the Briefcase, and then click Update All.
To sync using Briefcase with removable media
1- Copy the Briefcase to any type of removable media.
2- Remove the media from the first computer and insert it into the second computer.
3- Make any changes you want to the files in the Briefcase on the removable media. Do not copy the Briefcase from the removable media onto the second computer.
4- To sync your changes with the first computer, remove the media from the second computer and insert it into the first computer.
5- From the first computer, open the removable media folder, right-click the Briefcase, and then click Update All to sync any changes you have made.
