How to Cut Off the Outer Shell of a Golf Ball
Intro: How to Cut Off the Outer Shell of a Golf Ball
What you will need:
A saw
A Flathead screwdriver
A sharpie marker
And a golf ball
A saw
A sharpie marker
And a golf ball
STEP 1: Marking a Line
First you want to take your sharpie marker and draw a straight line around the circumference of the ball.
Then take your saw and cut along the line until you can see a different color inside the cut, do this all the way around the ball.
STEP 2: Prying Off the Shell
Now take your Flathead screwdriver and wedge it under one side of the shell by twisting it back and forth.
(BE CAREFUL IF THE SCREWDRIVER SLIPS OFF THE BALL AND HITS YOUR HAND IT HURTS!)
Once you get the screwdriver under one part of the shell shift the screwdriver a bit to the left and continue prying. Do this until the shell pops off.
STEP 3: Still Prying Off the Shell
Now wedge the screwdriver under the other half off the shell and pry it off just like the first half.
10 Comments
verence 13 years ago
RussellW43 7 years ago
If you have a homemade air cannon (potato gun) with a 1.5-inch barrel and have an adventurous imagination when it comes to ammo sources, then you probably already realize that the 5 cm golf ball is just a little too large. But, if you peel off the outer layer to reveal the inner core, you will find that it is almost a perfect match for your barrel. They are very fast; the most impressive thing (projectile) that I have ever shot from my air cannon. Be careful and good luck finding them after they have been shot.
ironsmiter 13 years ago
subtract shell.
Superball!
dombeef 13 years ago
chessman908 13 years ago
jj.inc 11 years ago
Fill with magic stuff, glue together with WEAK glue.
Now, GO NINJA SMOKE BOMBS!
