Introduction: How to Make a CarDrive
This is a car-shaped flash drive. It is NOT how to drive a car.
I made this in about 20 minutes, it was pretty easy to do.
I am sorry if this is the same as about 5 other instructables, I did not even know they existed.
Step 1: Materials and Tools
You will need:
A Hot Wheels car
An old flash drive (with a broken case if possible)
Superglue
Tools
A drill and bits
A Dremel with a small cutting wheel
A Phillips screwdriver
A hacksaw
A Hot Wheels car
Superglue
Tools
A drill and bits
A hacksaw
Step 2: Opening the Flash Drive
If your flash drive is broken, skip this step.
One of my flash drives was.
One wasn't, so i had to cut the pieces holding it together.
This step can vary depending upon your flash drive.
Make sure to keep the cap.
Step 3: Drilling Out Rivets
Most of the Hot Wheels cars I have seen have been put together with rivets.
This is how mine were put together, but some may use screws, in which case, just unscrew them and take it apart.
For rivets, find a drill bit that is quite a bit bigger than the hole in the end of it, and drill a hole in the rivet.
Some cars have two, some have one.
Step 4: Prying Apart the Body
Pry the top from the bottom, pretty simple step.
Note: Do not try to go in between the wheel and the bottom, this will wreck the axle.
When this is done, take out the seats. They are not glued in.
Step 5: Cutting the Rivets
The rivets may be in the way of the flash drive, if so, cut them out with a small Dremel cutting wheel.
Step 6: Cutting the Body
Cut a hole in the back of the body( the side with an exhaust pipe) big enough for the drive to stick out.
File the hole smooth.
I got lucky, and my cars had holes in them so I could easily remove the peice that I cut. If you aren't so lucky, you can finish the cut with your Dremel.
Step 7: Glue It Together
Glue the windshields to the top of the car.
Now add the flash drive and glue it to the bottom of the car, and glue the bottom to the top.
Step 8: You're Done!
Now just plug it in, and it will light up!
