Introduction: How to Make a Bowline Knot
A bowline knot forms a loop that does not slip.You can use it for sailing , camping , and even fishing.The good thing about it is that it is easy untie, even if it is really tight.
Step 1:
Position the rope so the end of the rope is facing you and the rest is away from you.Hold the main part of the rope snugly about three feet [90 cm] from the end.The size of the loop will determine the distance.Ten inches [25 cm] farther down the loose end , roll the rope between your thumb and forefinger to the left , allowing a small loop to form.Hold the loop.
Step 2:
Insert the loose end of the rope back to front through the small loop , creating a large loop.
Step 3:
Continue by taking the loose end above the small loop , then continue to the right around behind the main rope and down through the front of the small loop.
Step 4:
Pull the loose end and the main rope tight.
Step 5: How to Untie Your Bowline
Pull the little ''U'' shaped piece of string as shown in the picture.
