Introduction: How to Make a Canvas Mask
today were making a mask from canvas
you will need
plastic canvas
yarn
i used duck tape to cover it but you don't have to
scissors
a marker
a yarn needle
you will need
plastic canvas
yarn
scissors
a marker
a yarn needle
Step 1: Draw Your First Designs
when drawing out your mask knowing a little measuring and sometimes paper modeling helps too
(Plenty of references around everywhere on the net.)just type it in on any search engine
draw two equal haves of the same shape
Step 2: Cutting Out the Halves
make sure there are two sides
Step 3: Making the Top of the Mask
draw a square with your marker on the canvas as you did before with your previous shapes
and cut it out
and cut it out
Step 4: Continuing the Top Cut Out
draw and cut another piece (TIP- sometimes following the pictures is easier for me to do for me so bear with me here)
Step 5: Start Sowing the Pieces Together
sow the pieces together it is sort of like a cube when it's done
Step 6: Building On
when you sow the other parts on it should be starting to take shape
Step 7: Sealing Up the Top
draw@cut out the other parts and sow them on( if you have to make small adjustments its okay I had to,look at the picture)
Step 8: Preparing for Eyes
cut out a rectangle
to sow on like so
to sow on like so
Step 9: Building the Jaw
cut out four squares to make a half cube that will fit to the mask
Step 10: Putting the Jaw On
when the jaw is sowed on cut a resess for the next part
Step 11: Making the Muzzle
make a box over the area your nose will go
