Introduction: Finger Snowboard
my friends are wonderin how i made this so imma show you
Step 1: Materials
materials:
hot glue
wood glue or tacky glue
laquer/clear coat
brush
a can filled with water
tape
scissors
pen or pencil or a marker
filer
sandpaper
plywood
and a tech deck/fingerboard withour trucks
and a printer
hot glue
laquer/clear coat
brush
tape
scissors
filer
sandpaper
plywood
and a printer
Step 2: Plywood
first with the plywood you take your fingerboard and trace around it.
make sure you trace to of them
then you cut it out.
next you take you wood/tacky glue and you smear it around with your finger.
then you stack them and let it dry for a few hours.
after that you file down with the filer and then make it smoother by sanding it down with sandpaper
and after that you have one more step with the ply wood.
all you have to do is laquer/clear coat it.
clearcoating it will prevent the ply wood to get messed up.
Step 3: Looking for the Fingerskates
'''''''''''''''to get the skates to put on your bored you have to go to youtube.
then type in how to make fingerskates.
then click the 2nd vid that says how to make fingers rollerblades
then you go to the description and click more info.
then click on the link.
a window will pop up you maximize it and scroll down until you see diy paper skates.
then you right click it and press print.
make sure you print 2 of them.
Step 4: Putting the Skates Together
'once you printed them out you will need to cut them out.
then fold all the little corners.
then tape em up.
then your gonna get ready to put it all together.
then tape em up.
Step 5: Putting It All Together!!!
'after you have done all of that you have to put the skates and the board to make a fingersnowboard.
all you have to do is take your hot glue and glue the skates to the board.
make sure the skates are not to close and not to far.
Step 6: Fingersnowboard!!!!
after your all dont you have a fingersnowboard!!!
this is actualy really fun to play with.
so go on and snow board!!!
