Introduction: How to Make a Homemade ON/OFF Switch
this will show you how to do a homemade ON/OFF switch with stuff ou can find around the house from little to no cost to you
Step 1: Get All the Materials Needed
Give a general description of the Stepok so this will be very cheap...
- 2 paper fastners
- 1 paperclip (preferably small)
- 1 sheet of paper (not too big,all you need is 3 cm x 1 cm) -> you can get something harder,like cardboard so the switch doesn't break like mine did the first time
- a battery (i used a 9v because that was easier for me.you can use a 3v cell battery,whatever)
- 2 paper fastners
Step 2: Get All the Tool[s] Needed
so all you need is an xacto knife or some scissors...
Step 3: The Board
cut out a piece of paper ~3cm x 1cm
Step 4: Make Some Holes
make some holes (2) big enough for your thumbtacks or something
Step 5: The 2 Pins
put the thumbtacks as i did in the pic (or try to)
Step 6: The Thing That Connects the 2 Pins Together
ok so now place the paperclip as i did in pic (open it a little bit and then close it)
Step 7: Test It!
in the 1st pic,the paperclip touched only 1 thumbtack which touched the LED
the other thumbtack touched a metal bar which was connected to the battery
because the paperclip touched only 1 thumbtack ,it wouln'd allow the electricity to traver trough it to the LED
in the 2nd pic,the paperclip touched both thumbtacks which allowed the electricity to traver trough it and get to the LED
Step 8: Finished
well you are finished
enjoy your homemade ON/OFF switch!
check my other instructable
https://www.instructables.com/id/how-to-make-a-very-simple-robot/
Step 9: Questions
any question,comments,ideas on how to make it better?
post them here!
please rate my instructable.
post them here!
