Introduction: How to Make a Leg for a Sofa Chair
two pieces of 3/4 ply one piece of 1/2 ply same color of sofa leg your going to duplicate
measuring tape, glue, a pencil and clamps, table saw, miter saw, belt sander.
Step 1: Making Your Lines
first you will need to measure existing legs width, and then transfer measurement onto 3/4 ply but add a quarter on in inch more. Now do the same on the 1/2 inch ply
Step 2: Ripe Ply
Now with a table saw rip ply-woods to desired width
Step 3: Cutting With the Miter Saw
Now measure legs length and transfer length to the pieces of plywood you ripped but give yourself a quarter of an inch more to measurement. then cut them
Step 4: Trace to Ply
now you trace leg onto all pieces of ply
Step 5: Sand to Disired Size
Now with a belt sander and grinding disc sand all pieces of ply to desired size
Step 6: Trace and Cut
Now you lay your cut pieces of ply and you trace the out line of how they meet. then you cut them on miter saw then line up again until you have a rough cut out of your leg
Step 7: Rough Outlook on Leg
this is what it should look like before you glue
Step 8: Apply Wood Glue
Now you apply wood glue to all pieces
Step 9: Clamping It
Now you clamp it tight from all angles
Step 10: Routing the Edges
Now you will need to route all edges to a 1/8 inch round
Step 11: Finished Leg
Now your all complete. You will need to find correct threaded bolt rode drill and glue new rode in.
