Introduction: How to Make a Longbow String
you will need
drill
clamp
a sharp tool
string to start off u need 2inchs longer in string then your bow
drill
clamp
a sharp tool
Step 1: Cutting the String
cut the string 2inches longer then your bow like i did.
Step 2: Tieijng the String
tie the string in to a knot to hold it tight
Step 3: Puting in Vice
now put the knot u just tied in to the vice tight
Step 4: Puting in the Drill
put the end of other side of the string in to the drill and tighten then spin the drill to twist in this form.
Step 5: String
now your string should me tight like this but not to tight or it will curl up when you take it out of the vice.
Step 6: Tie the Knot
take it out of vice and drill and tie the side in the drill like you did the one in the vice
Step 7: Tie the Loop
now tie in to a loop that will fit your bow snugly but not tight
Step 8: You Are Done
now you are done if this does break just add 1 more strand and it will hold up to 1-60 draw lbs
