How to Make a Version 2 Pinned Snap Trap Gun
Intro: How to Make a Version 2 Pinned Snap Trap Gun
intro:a air gun known as bb guns,pellet guns or airsoft guns use pressure to launch in this case a spring powered launcher
before we start we must go to the disclaimer which is below
THE AUTHOR WHO THOUGHT OF THE IDEA TAKES NO REPONSIBLITY TO OTHERS EVER,PLEASE BE CAREFULL NOT TO SHOOT SOMEONE'S EYE OUT NOT REPONSIBLE FOR ANY DAMAGE,INJURYS,EAR POPPINGS,INCIDENTS,LOCKDOWNS,OR LAWSUITS NOW IT IS ILLEGEL TO TAKE THIS IDEA WITHOUT PERMISSION THIS IS NOT MEANT FOR ANY REASON OF REPORTING A WEAPON ARTICLE AND GETTING IT DELETED THIS IS A REPONSIBLITY TO EVERY BUILDER, AND SHARP SHOOTER USING THIS. THIS IS NO TOY AND SHOULD BE TREATED WITH RESPECT YOU CAN USE THIS IN AIRSOFT AS misuse or caseless use may cause serious eye injury particulally the eye and neck.this is intended for use by those 14 years old and olderread all instructions before using.the buyer and user have to follow the duty of following all laws about the ownership of this airsoft gun.you and others with you
should always wear ear plugs or ear muffs as well as safety glasses .be carefull shoot safely and do not attempt to shoot at
eyes,neck or other areas of pain,this is not a fool around toy,no reponsiblity claimed execpt from the shatpshooter,the buyer and
the supervisor please give credit to crosman for parts of the disclaimer
AIRSOFT CATAPULt THE WHOLE REASON OF THIS ARTICLE IS BECAUSE IT'S LIKE A PATENT THAT'S FREE OF MONEY COST
to make one the stuff you will need per each one is shown in the image below
which includes a target,lineman's pliers,beads, two 50 mm paper clips,safety glasses for war games you will also need ear protecting ear muffs,electrical tape, a target and obvosivsly a snap trap
STEP 1:
STEP 2:
STEP 3:
first before you start put on protective ear muffs or ear plugs then put on safety glasses then to load up insert a bead and then to tension up the launcher pull the bar back if you are in zero gravity also hold onto the bead with every part of you away from the front of the snap trap for safety then to aim it may take pratatice to get it correctly and may sometimes need to adjust the angle depending if it's a mouse trap or rat trap to shoot just let go of the bar now it's loud enough to pop your ear buds sometimes however not everytime so for safety you must ether wear the hearing protectors and the max daily exposure time for every 28 hours a day everyday in cilvillain time with ear plugs or ear muffs that portect a minnium of 26 delicbells loud remeber if you are using ear plugs do not stick it too deep into your ear compared to ear plugs ear ear muffs are more sanaitary and more safer
