Introduction: How to Make Cheap Temporary Sliding Gloves
This is how to make cheap and inexpensive sliding gloves. They are 1 time use. They might be good if you don't really know how to slide yet and you don't want to spend alot of money on something you might not like or be very good at.
Step 1: What You'll Need.
You will need 2 thin plastic gloves like the ones doctors use. A rock that is a good size. Not too big not to small. This will be your puck you slide on. And alot of duck tape.
Step 2: Time to Start Making It.
First take 1 of your plastic gloves and put it on.
Step 3: Making the Puck
Put the rock in the second glove so the back of the rock will fit comfortably in your palm.
Step 4: Now Is the Tricky Part.
With the empty glove on your hand put the glove with the rock in it on the same hand. make sure the rock is in your palm cofartably because after this it is imposible to move.
Step 5: Time to Get the Ducktape.
Now take the ducktape and put it all over the rock. Dont let there be 1 bit of glove showing over the rock. Put down plenty of tape because this is what keeps the glove from ripping and keeping the rock from moving or falling out.
Step 6: Breaking in the Glove.
This won't take long at all. Don't try to slide before you break them in. If you do it might bite the ground too much. To break them in get going on your board and drag the rock on the ground until you can see the rock. The duck tape on the glove will still hold it even though the rock is showing. If you notice the glove is bending and the rock is sliping, put some more duck tape on the side that is slipping.
Step 7: Finished
You are finished you have your next to free, cheap, 1 time use sliding gloves. Once you take them off they are hard to put back on, if you can, so i would recomend leaving them on unless you are finished using them. Please leave comments so i can improve my disign.
8 years ago
Are you sure these are going to work?
