Introduction: How to Make Forging Tongs
Step 1: Supplies
for this you will need;
1/4 in steel sheet metal
three washers
bolt
lock nut (or a regular)
tools;
arc welder
plasma torch
argon
compressor
welding protection
wrench
grinder
sharpie
three washers
bolt
tools;
arc welder
plasma torch
argon
compressor
welding protection
wrench
grinder
sharpie
Step 2: Make the Tongs
draw the shape of one side of tongs on the metal
draw it again
cut it out with the plasma torch
(due to the fact I don't want to kill my camera, there are no pictures of welding or cutting)
grind down the sharp edges
drill holes at the pivot points
put a washer between the tongs and on both sides and screw the nut on
draw it again
Step 3: Make the Grips
also cut out two small rectangles
use the grinder to put grooves in them
weld them on the tongs (make sure that when the tongs are closed the grips are flat against each other)
