Introduction: How to Make Phone Holder From Pvc Water Pipe
From my last Instructable on https://www.instructables.com/id/How-to-flatten-the... some friend askin me for makin instructable for phone holder. so is this a Instructable how to make a phone holder from flatten pvc water pipe.
you can view for step by step or just watc it on my video :
Step 1: Tool You Need for This Project
1. your phone
2.water pipe pvc who has flatted ( how to flatten pvc water pipe "https://www.instructables.com/id/How-to-flatten-the...
3.scissors
4.ruler
5.cutter
6.lighter
7.pencil
8.super glue (strong glue for plastic)
Step 2: Lets Make the Base Holder
-First , create a rectangle on flatt pvc. According to the size of your phonecell and cut of it.
-create a line right in the middle of the back of the pieces of pvc
-heat by burning with ligther. burn right along the line. fire don't get too big, too close and too long because it could burn pvc
-When the pvc was getting flabby on area burned, buckling, create a 45 degree angle.
-create a line approximately 1, 5 cm on one side, same way, burn on the line and bucking 20 degre
-the base of holder has created, next step
Step 3: Lets Make the Top Holder
-create a rectangular plate strip of pvc
-approximately 2 cm from one side is marked with a line
-burn on the line and bending, create a 90 degree angle. use your angle side phone for fitting.
- gift the marker line on the pvc fit on your phone, burn in the line and buckling fit on size your phone,
- cut approximately on the side that is bent. and make sure the bending is hold your phone.
-same way make a bent on the other side use your phone for fit the bend look at the picture.
- and make on the other plat but only in one side, Paste the 2 pieves plate which already formed, formed letter T use a strong glue.
-the Top holder has created.
Step 4: Last Step
-combine the two piece base holder and top holder using a glue look to the picture.
-and your phone holder is ready to use.
Nb. For more comfort to your phone and look beautiful, you can add layer iwith official fabrics, and put some accesories. :)
#Thankyou :) sorry for my bad language and the writing, my English is not really good
