Introduction: How to Make Pointed NERF Bullets
In this Instructable I will teach you to build and use pointed Nerf bullets
Materials you will need are:
-1 altoids tin to store darts
-regular streamline darts that you are willing to destroy
-syringe tips
-glue
-and scissors
Step 1: Getting Set Up
to get started you will need a well lit flat surface to work on. then you need measure how long the dart is.then measure how long the syringe tip is and divide the difference then cut the dart so that the syringe goes in and is still the same length as the original dart.
Step 2: Gluing the Syringe
stick the syringe tip about 2mm in and add glue around it
Step 3: Loading the Clip
when loading , for best results alternate between regular and pointed darts.
