Introduction: I-CAN-HOLD: MULTIPURPOSE PCB HOLDER
Introduction
Holding a PCB (Printed Circuit Board) while working on an electronic project is a common problem. A PCB holder is not only convinient but also saves time. This instructable introduces a simple PCB holder that can be made from 5 easily available parts and 3 tools in about 15 minutes. Complete project costs less than Rs. 25.
i-Can-Hold can hold small PCBs of various sizes at an different angles. It is small enough to be kept in pocket. Two i-Can-Holds allow holding of larger PCBs. Apart from holding PCBs, i-Can-Hold can be used for holding electronic components, screw gauge for measurements, photograph, small parts for assembly, etc.
Tools and Materials
Tools and Materials
- Metal file, 1
- Hack saw, 1
- M3 bolt with nut, 1
- Length of bolt should be more than the width of hinge
- Major diameter of bolt should be equal to or a little less than hinge axle
- 3" Al door hinge, 1
- 15 mm binder clips, 2
- Fifteen minutes
Step 1: Making I-Can-Hold
Steps required to complete i-Can-Hold
- One end of hinge axle is filed.
Axle is now replaced with corresponding nut and bolt.
- Nut and bolt allow angular adjustments.
0.3" cuts are made spaced at 0.5" on the hinge as shown in figure.
- These cuts are provided for accommodating various PCB widths. Binder clip can be inserted in these cuts.
- i-Can-Hold is now ready for use.
Step 2: Usage
Please look at the photographs that demonstrate the use of i-Can-Hold. Photographs are self explanatory. Still a little description is provided below for more clarity.
Usage
Usage
- Saw cuts accommodate of various sizes of PCBs.
- Binder clips are used for holding PCBs and other components.
- Two i-Can-Holds can be used for holding large PCBs or parts.
- i-Can-Hold can act as stand for screw gauge. Hence, making both hands free for taking measurements.
