Introduction: IPod Shuffle Gen 2 (New One) Travel Case
Ok, this will only work for some people as it requires you to own a pair Apple in-ear headphones to use their case. I wouldnt recomend buying some just for the case couse they plain suck as headphones if you ask me. Maybe you can find just the case on ebay but i doubt it.
The size of their case is perfect for the shuffle plus whatever earphones you use. All it needs is one tiny alteration. Just cut out the two pins in the inside of the case which are absolutely useless. I used a dremmel and a fiberglass cuting disc.
Once you remove the pins, youre done! A perfect Apple branded case for your new second generation iPod shuffle, even before Apple releases one themselves!
Step 1: This Is All You Need...
All you need is the case of one of these Apple In-Ear Headphones.
Step 2: Cut Off Those Useless Pins...
Ok all you need is to cut off those useless pins using a dremmel fiberglass cutting disc or whatever other method you choose. Make sure its smooth, you wouldnt want to scratch your new iPod.
Step 3: And Youre Done!
Now just put your shuffle and headphones in there and wrap the cable around the rail and youre done!
A brand new Apple branded ipod Shuffle Gen2 Travel case! Its very useful for when you wanna take it inside your backpack and keep it safe from scratches, bumps and dirt.
