Introduction: IPod Touch Case With Stand
This is my first instrctable so sorry if it not perfect. :) This is an iPod touch case with a biult in stand. It can have four veiwing angles and is really cheap.
Step 1: What You Need.
The supplies for this project are:
-A hard iPod touch case (mine came from China for 1$)
-3 nuts of any size
-2 bolts the same size of the nuts
-Utility knife
-Epoxy glue
It does not matter what size the nuts are but the larger they are, the more they stick out.
-3 nuts of any size
-Utility knife
-Epoxy glue
Step 2: Glueing
Use the utility knife to rough up three corners of the case to make the epoxy stick better. Put a little bit of epoxy on the coners but not too much or the nuts will get full of glue. Put the nuts on the glue and put some more glue around it to make sure it doesnt slide. Let it dry and make sure to nuts stay in the same place or your stand will be crooked.
Step 3: Finishing
When the glue dries, all you have to do is screw the bolts in to two nuts and you have a stand that is very versatile.
