ISight Tripod Mounting Bracket
Intro: ISight Tripod Mounting Bracket
I always find myself taping down, propping up, or hanging my various web cams or my iSight camera from books, shelves, or boxes throughout the house- if i am doing a time lapse project or setting up a cam for video surveillance, this gets to be a big pain.
I needed something to hold various cameras where i wanted them, easily adjustable, and easy to move somewhere else without taping and tying.
So here we come to this VERY inexpensive, easy, ultra-functional bracket for various cameras that require special mounts ---for use with any TRIPOD.
STEP 1: Gather Materials, Cut Plexi, and Get Ready to Heat and Bend.
Mark your plexi the approximate size you need. (The base should pretty much cover the tripod mounting bracket, and add about 2 extra inches length for the bend and the small lip.
Once the plexi is marked, cut it off, then mark for holes and folds.
Bend the small bend first, (this is going to fit inside the isight camera mount) and you will glue a separate smaller piece of plexi right under it later to add a little meat to this area.
STEP 2: THE HOLES!
Mark the spots for the hole(s) (if you are using the bracket for more than just the iSight)
Drill the 7/32" holes.
Heat up your screw that you will be using to make the threads and turn into the holes... working back and forth until the metal cools a bit.
STEP 3: Mount Up Your Cam or ISight.
Once holes have been "threaded" and materials have cooled, go ahead and give it a shot.
I took the laptop mount for the iSight and adjusted the tension screw to clamp onto the bend we made in the plexi... quite solid. works good, now you can adjust the rotation, height, tilt, etc... of the isight and since it's on a tripod you can adjust all that too.
The second pic here shows a smaller "bullet" style cam that i use sometimes, this is also a very solid mount and totally adjustable.
You could go nuts and add all sorts of clips and other screws to mount whatever you have, add different bends, different angles, etc...
Thanks for checking this out.
my website
my website
4 Comments
tlmurray 14 years ago
I have them for sale on eBay, item 160404303393, with several photos of applications.
fleanine 16 years ago
theking 15 years ago
PetervG 16 years ago
