Introduction: 12V Solenoid Beam Engine, Built From Aluminium Scraps and Scavanged Componants.
This is how I built a little beam engine powered by a solenoid which runs on 12v DC.
Due to the harsh winter I have been stuck in the house most of the time over the last few months, before Christmas I gathered up all the old hard drives, CD ROMS, Floppy drives, a zip drive, 2 printers, a flatbed scanner and a video recorder that where no longer working or no longer any use, after a couple of days of dismantling all this i was left with several boxes of very well made components to be put to use in other projects.
I decided that if i could not venture out into the shed, then the shed must come to me. So I setup a work bench in a corner of my computer room and brought the piller drill and a selection of hand tools in out of the cold.
I bought a decent 6" combination square with scriber for this project, I have a 12" version of this already but the smaller one is much easier to work with on smaller projects.
I visited Banbridge Coach Works a month or so ago and asked if i could buy some of their cuttings of aluminium, I gathered up an armful of various pieces and was asked for £15 which I gladly payed.
Many years ago when I was an engineering student I built a model steam engine as my end of year project which earned me a distinction. Since then I have had a love for all types of steam engines. In more recent years i have become fascinated by sterling engines and more recently solenoid engines and Froment engines.
This is my first real project that has mainly used aluminium, back in the day we used very little aluminium as it was much more expensive than steel and was an absolute bugger to weld. I recently discovered Durafix Easy Weld rods which is a low temp welding rod for aluminium and non ferrous metals.
Design wise this project just sort of happened, it followed no set plan other than I wanted it to have a walking beam as part of the mechanism. because of this there are some stages that I don't have pictures of, there where a few dead ends on some of the stages but then again certain failures led to better ideas.
Materials used:
1" x 1" alu angle
3" x 1" alu angle
6 x 6 mm alu bar
5mm alu plate
3mm alu plate from an old Hard drive
20 x 15mm alu channel
10 x 5 x 5 roller bearings (RC car type)
12v solenoid from an ancient telephone switch board.
various nuts bolts and washers
various components salvaged from old computer and household tech goods.
Tools used:
Almost every thing I have, including the bathroom sink ( which required quite a bit of cleaning afterwords )
Pillar drill
Drill vice
Band saw
sanding table
Dremil type thing
Durafix rods
Blowtorch with propane / butane mix gas
Hand tools, including
Junior Hack saw
numerous small files
numerous needle files
tap wrench and taps.
2 part Epoxy
superglue
DW40
I had planed to make a governor for this engine and also to try and power it with a solar panel, for now the project is finished, I will continue tinkering with this engine and will post any modifications I make as they happen.
To save much typing there will be a brief description of each stage, the bulk of the info will be on the photos.
Thanks for looking, I hope you liked my design
Step 1: What Is a Solenoid Engine.
The solenoid engine or electromagnetic engine also known as a pulse motor was the forerunner to the modern electric motor. the following is taken from The Old Model Company who sum it up much better than I can
When Michael Faraday in Great Britain and Joseph Henry in the United States both discovered electricity at roughly the same time no one knew what to do with it because in those days nothing worked on electricity.
In the thirty or so years that followed, between 1831 and 1861, the great experimenters of the day tried to use this new discovery by copying steam engine design and practice.
Many early electromagnetic engines were of reciprocating design and used connecting rods, beams and flywheels that had to be constantly accelerated.
These early reciprocating engines were quickly followed by revolving armature designs of which Paul Gustave Froment’s was the first in 1844. These were much more efficient and a variety of different and increasingly sophisticated designs emerged.
To fully understand the unique properties of the solenoid engine you need to track down a copy of Secrets of the Electric Motor (it out there on the interwebs if you know which stone to look under)
This video is a scientific lecture is not for the faint of heart as it kicks some major science re many of the properties of the modern electric motor that we just take for granted because we know the motor works rather than learning why and how it works.
I lost my only copy of this video so I'm a very rusty on the topic, but if you can find this video you will learn allot maybe even more that 1 brain can handle. the video explores work by Tesla plus the other great minds of that golden age and more recently John Bedini who's motor has achieved over unity (if you mind is open enough to believe such things)
I intend to explore the world of the Bedini motor as part of a future project once i get my lathe operational and my engineering tolerances back down to those i was once capable of back in the day.
Step 2: Why Built It?
Why not?
I built this for the following reasons.
To see if I could
To rekindle many of the skills I have let lapse in the years since I was an engineer by trade.
To indulge myself my fascination with all things of a mechanical nature. (but not the internal combustion engine, I have no interest in those at all)
To educate myself re electronics.
To build something that incorporates many of the features of the steam engine (Steam engines are my idea of engineering bliss) without the danger of fire and high pressure steam.
But my main reason for this project was to give me an indoor project to keep me occupied through this very harsh winter, something more fulfilling than spending the next few months in a prescription drugs based haze waiting for the spring to arrive. ( PS. I'm still a bit hazed on it at times but at least I'm doing something better than sleeping)
Step 3: The Base
Until the engine was complete I used a scrap of 20mm plywood as a base, this alowed me to reposition the various components as i went along.
The display base was cut from an old pine bed frame using the bandsaw and then sanded on the sanding table.
Step 4: The Flywheel and Crank Shaft.
The first thing I built was the flywheel assembly.
The flywheel started out as a motor from a video recorder.
The ring magnet and coils where striped out just to leave the flywheel and bearing.
The crank was made from a brass spindle from a CD ROM drive and screw out of a rubber damper also from a CD ROM drive.
The flywheel was mounted on a piece of 3" x 1" alu angle.
A platter from a 2.5" Hard drive was used to face the flywheel and was glued on with 2 part epoxy.
Step 5: The Beam.
The beam was cut from a cutting of 5mm alu plate.
The beam is 5" long x 1" wide. the beam tapers from the center to the ends.
The beam was marked out first and then cut out on the bandsaw and ground to shape on the sanding table.
The beam was not originally designed to take bearings but just bolts, I discovered I had some bearings and used them as the eliminated all the play that the original bolts had.
I applied a thin film of superglue into the holes with a toothpick and then pressed the bearing into place.
Step 6: The Tower
The tower started out as just to brackets made from 3 x 1 alu angle, this was mounted on a wooden block to raise it up high enough. Then i discovered some 20 x 15mm alu channel in one of the sheds and used that to make the bottom of the tower, the base was cut from a 3mm alu plate from an old hard drive.
The components where drilled mainly for cosmetic reasons but some are placed to aid in the task of clamping the pieces together before they where welded together.
The tower is welded using Durafix easy weld rods, i will not cover this now as I still getting the hang of this amazing stuff, I plan to do a Ible on how to use this stuff to its full potential in the near future.
The tower is approx 5" high.
Step 7: Trial Erection (fnarr Fnarr)
Back in the day our engineering instructor was taking us for a theory class, He told us that he would allow us five minutes to get all the laughing and jokes over with about the next engineering term he would use, he then told us about trial erections (fnarr fnarr)and indeed we di need the 5 mins before things settled down again.
Anyway...
With the tower and beam in place on a scrap piece of plywood, i was able to mount the flywheel in the right position.
I used light gauge wire as temporary linkages, these help in deciding where the flywheel etc will be placed.
The original solenoid was a small plunger type one that was just to small and over heated very quickly, I then decide to use the large hinge type solenoid from a telephone switch board, I runs well on 12v but would probably have been 50v.
I had toyed with mounting the solenoid so that the flat would be pull the linkage directly down but then the mechanism would have to lift the weight of the flap and that would kill the momentum so I deiced to go for the overly complicated L shaped linkage.
Step 8: The Solenoid.
The solenoid i had planed to use was way to small and over heated in seconds, so when I discovered i had this one in the shed i used it.
I was going to mount the solenoid with the flap on the top so it pulled the linkage directly down, but then the flap would have to be lifted back up with the momentum of the flywheel.
The decided to mount the solenoid with the flap mounted vertically with hinge at the bottom, this way less effort would be used to return the flap to the open position.
Step 9: The Overly Complicated L Shaped Linkage.
This linkage transfers the horizontal action of the solenoid into the vertical action used to lift the beam.
I don't even know if I could explain how I made this.
You should be able to get the idea from the pictures.
I watched almost all the episodes of Sons of anarchy series 2 while making this, I could have made a simpler linkage but this was more to see how good the Durafix welding rods where.
Step 10: The Linkages.
The ends of the long linkages are made from 1" alu angle and are joined with a 3mm machine screw with the head cut off, nyloc nuts where used to secure the end to the threaded bar.
the end that runs on the crank pin was bushed using Durafix, the hole was drilled over size and then filled in with Durafix which has a very high tensile strength so it will wear much better than the standard aluminium. the weld is then filed flat and re marked and then drilled to the correct size.
The square end of the long linkage was made from 6mm square alu bar filed to be a sliding fit for the L shaped linkage.
Step 11: The Contact Switch.
The contact switch started out as a spring loaded rocker switch that is found on most CD ROM drives.
A 4mm nyloc nut was attached to the switch using epoxy putty, once it had cured it was filed to shape.
The metal clip from a pen was used to extend the lever of the switch so it will take less effort to move the switch.
The clip was attached to the switch by crimping it slightly so it was a snug fit, then a small blob of hot melt glue was applied to the clip and it was pressed into position while still hot.
to make the cam a small nylon pulley was drilled out to fit the shaft and a screw was used to act as the cam.
Step 12: Wiring Diagram
Its not rocket surgery.
Step 13: Final Assembly on Display Base.
The base was marked with a lateral center line using a water soluble pencil.
First the tower is fixed in position.
With the tower and beam in place the crank linkage is fitted and this then determines where the flywheel assembly is fixed in place.
With the beam in the horizontal position the position of the L shaped linkage can be established.
Finally the solenoid can be fixed in position, making sure that the mechanism runs smoothly.
Step 14: Finished at Last.
And there we have it.
I hope the Instructable made sense.
I may come back to this engine at a future date to do some slight tweaks, but to be honest I'm kind of sick of it now. I will try and make a better cam and contact switch though.
If i do make any changes I will post details.
I am going to build a Froment engine as my next project once I get my metal lathe going.
Thanks for looking and I hope you liked my ideas.
3rd Epilog Challenge
