Introduction: 3D Printed Hinges
I designed some hinges which can be printed out on UV-curing printers. This was partially to figure out how to make compound parts using an Objet printer and partially to figure out the various tolerances. I found that I can scale the hinges down to have roughly a 10mm height. At this size they will work with even a 0.25mm gap between the pin and the hinge. Although, it is preferable to have a 0.5mm gap. These hinges can be scaled up and scaled down as needed, and consists of three parts. The only difference between each set of hinges is the diameter of the center pin. Hopefully these files will prove useful to someone.
Update: The files that start with 5 and 7 are better and beefier hinges. They have 5 and 7 rungs respectively.
hinge1bottom (repaired).stl
hinge1pin (repaired).stl
hinge1top (repaired).stl
hinge2bottom (repaired).stl
hinge2pin (repaired).stl
hinge2top (repaired).stl
hinge3bottom (repaired).stl
hinge3pin (repaired).stl
hinge3top (repaired).stl
5bottom (repaired).stl
5pin (repaired).stl
5top (repaired).stl
7bottom (repaired).stl
7pin (repaired).stl
7top (repaired).stl
