Introduction: 3d Printer Filament Storage
About: I'm an industrial maintenance technician by trade. That means I'm pretty good at about 100 different trades. In my free time, I like to tinker. I'm always doing electronics projects but lately, I've been down …
You can find this article and others at my website.
A lot of 3d printer filament is what’s called “hygroscopic”, meaning it absorbs moisture from the air. This will affect the filament diameter and reduce the appearance and strength of your printed part.
Filament Storage Blanket Advice
It’s important to take your environment/climate into consideration. I see a lot of people on 3d printing forums saying moisture doesn’t affect filament because “I leave mine out all the time, no problems”. It’s true that if you live in Nevada, USA where the average humidity is 30% then moisture probably isn’t a problem. However, I live in Georgia, USA where the average humidity is around 70%. Therefore, a filament storage solution that resists moisture is an absolute necessity.
Effects of “wet” Filament
During printing, as the filament is extruded through the hot end, the moisture will rapidly evaporate. If you hear your hot end hissing and popping as you print, it is likely your filament has absorbed moisture. This leads to voids and defects in your printed part. I have often seen people spend countless hours troubleshooting their extruder and hotend due to reduced print quality while the problem was the filament, not their printer.
Step 1: Drybox With Integrated Filament Roller.
I designed and built a filament storage box with integrated rollers. As you can see, the tubing guides the filament from the box to my extruder. More information on the Thingiverse page.
For desiccant, indicating desiccant packs are good. However, once the desiccant in the packs is saturated you have to open them to “recharge” (dry them out in the oven) them. So you’re then left with loose desiccant beads. This is why I like EvaDry. It has a heating element built-in so to “recharge”, you simply plug the unit into a wall outlet for a few hours.
Step 2: Don't Open Your Filament Until You're Ready to Use It.
Most filament manufacturers vacuum-seal their filament with a desiccant package to protect against moisture.
Step 3: Vacuum Storage Bags + Desiccant Packs
These work pretty well for filament storage. Make sure to get the kind that you can use a vacuum cleaner or hand pump to suck the air out and not the “travel” kind that you roll up. Use desiccant packs and be careful around sharp objects.
Step 4: Gasketed Storage Bins + DampRid
These are more durable and convenient than the bags. However, there’s no way to suck out air to minimize moisture trapped inside. Plus, you’ll likely be reintroducing a large about of moisture every time you open the lid. As such, silica gel desiccants can’t really keep up. Because of this, I recommend DampRid. You can buy it in a ready-to-use container or in bags to refill those containers. It’s cheap and effective.
