Introduction: 4x4x4 LED Cube Upgrade With Shift Registers (74hc595)
I had about 70 LEDs, and an arduino. I wanted to build the cube with stuff that I already had, and using as little new stuff as possible. I built my using 64 LEDs, and 4 resistors and I would have used bus wire, but I didnt have any, so I used galvanized steel wire from the hardware store (baling wire?). I had to use wire to connect the LEDs, since had been clipped to about 1/8" lead length. To connect the LEDs to the arduino, I used an old IDE cable, because its so convenient for transferring parallel data. I was going to need 20 wires, so one ribbon cable keeps things tidy, and easy to trace. I did this project on a holiday weekend, and I wasnt able to acquire a SIP header, but I was able to make due with a couple paper clips, straightened, and clipped to about 1/2".
I had some problems finding software that would work, because I made my cube common anode, Instead of common cathode (I was thinking of only using 4 resistors, and thought they should be on the positive side, not the negative side...) Since my cube was made up of 4 layers of 16 columns, I used 4 220ohm resistors on the plane pins instead of 16 resistors on the column pins. I figured I could always change the code, but that turned out more challenging than I had anticipated. I have since revised my cube to use 16 100 ohm resistors, instead of the 4 220s, and It is much more evenly lit.
It should also be noted, that the LEDs that I used were in circuits with 3 batteries, they seem to run at about 4.5v. When re-using IDE cable, every other wire is one side of the connector, so if you only use one side (like Im doing), you only use every other wire, this also turned out to be quite handy when hooking up 2 8-bit shift registers.
This worked great, but it used all the pins on my arduino, and I wanted to try to add things, things that will need some of those precious pins. The arduino had some nice programs for using shift registers (74HC595s specifically), so that is what I used.
There are many examples of using LED cubes, so I wont go over that part, this is about converting the cube from parallel to serial using shift registers. With the new code, and use of shift registers, you can expand this cube to virtually any size, you can also add features (buttons, knobs, sounds, sensors, motors,...)
This project needs:
1 4x4x4(64) LED cube, assembled, and working.
2 74HC595 Shift Registers.
1 IDE cable
9 SIP header pins.
Arduino + USB cable + computer to program.
1 USB cell phone charger (to power the cube when not hooked up to the computer.)
You will also want some kind of container, or board to mount your project.
Tools:
Soldering iron/solder/flux/alcohol (Soldering and cleanup)
Tweezers, Pliers, Diagonal nose cutters, knife (for wire and chip prep)
Step 1: Build and Test an LED Cube.
Follow one of these instructables, and build yourself a 4x4x4 LED cube, or build a different size cube, and modify the software to suit your cube size.
If you build a 4x4x4 or smaller cube, you can hook it up(similar to the way shown above), and test it out, and test the software. If you want to build a bigger cube, you should probably start with a smaller cube first, then move on to bigger, after you have some experience with the smaller cubes.
Links to 4x4x4 cube Instructables
https://www.instructables.com/id/The-4x4x4-LED-cube-Arduino/
https://www.instructables.com/id/4x4x4-LED-Cube-Arduino/
https://www.instructables.com/id/Arduino-4x4x4-LED-Cube/
Step 2: Rewire Your Arduino Connector
Step 3: Prep Your Chips
If you are soldering them into a board, you just need to bend the leads so the chip fit it easily. if you are piggybacking your chips like I did, then you want to bend the leads out on the pins where you are going to terminate your wires. the other leads stay down so you can terminate them to lead on the chips below.
Step 4: Prep Your Wires
Here you can see how 2 wires are a bit longer, to connect to pins on the other side.
Step 5: Start Building Your Piggybacked Chips (or Install Jumpers)
If you solder your chips into a board, you will need to jump a bunch of traces from one chip to the next. (like I had described in the previous step about prepping your chips)
Step 6: Solder Up Wires to the Chip Output Pins.
Step 7: Finish Up the Chips by Soldering Up Their Jumpers
Here is a decent web page I found on another site, its a pretty decent illustration of 2 shift registers daisy chained together. You may want to use it as a reference if you solder your chips onto a board, or are unsure about where to solder wires.
http://bildr.org/2011/02/74hc595/
Step 8: Solder Up Wires to Your Columns
Update: I've changed my cube around to have resistors on the colunm pins (100 ohm), instead of the plane pins(220 ohm). While I was there, I added a .1uf ceramic cap on the shift registers.
You can now turn off your iron, clean up your mess, and get ready for programming!
Step 9: Program Your Cube
Im including the software that I started with, other arduino users made it. Im also including 2 other version that I heavily modified to work with 16 bits of shift register. One file is tagged CA, the other is CC, the CA version works with a common anode setup, the CC version works with a common cathode setup.
Note: The common anode means each planes anodes are connected in common, The term common cathode, or common anode typically refers to RGB LEDs, but it applies here, since we dont have an even amount of cathodes and anodes (in an idea multiplexing environment, you have equal numbers of anodes and cathodes.) This cube design is less than ideal in that you have 4 and 16 control lines, instead of 8 and 8 control lines. Anode centric might be a more accurate term, but common anode conveys the idea, and if you are talking about a single plane, then common anode or cathode would be accurate.
Step 10: 4x4x4 Cube Code for 20 Arduino Pins
#include <avr/pgmspace.h> // allows use of PROGMEM to store patterns in flash
#define CUBESIZE 4
#define PLANESIZE CUBESIZE*CUBESIZE
#define PLANETIME 3333 // time each plane is displayed in us -> 100 Hz refresh
#define TIMECONST 20 // multiplies DisplayTime to get ms - why not =100?
// LED Pattern Table in PROGMEM - last column is display time in 100ms units
// TODO this could be a lot more compact but not with binary pattern representation
prog_uchar PROGMEM PatternTable[] = {
// blink on and off
B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0011,B0000,B0000,B0000,B0011,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0011,B0010,B0000,B0000,B0011,B0010,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0011,B0011,B0000,B0000,B0011,B0011,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0110,B0110,B0000,B0000,B0110,B0110,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0110,B0110,B0000,B0000,B0110,B0110,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0110,B0110,B0000,B0000,B0110,B0110,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0110,B0110,B0000,B0000,B0110,B0110,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0011,B0011,B0000,B0000,B0011,B0011,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0001,B0011,B0111,B0000,B0001,B0011,B0111,B0000,B0000,B0001,B0011,10,
B0000,B0000,B0000,B0000,B0000,B0011,B0111,B0111,B0000,B0011,B0111,B0111,B0000,B0001,B0011,B0111,10,
B0000,B0000,B0000,B0000,B0000,B0111,B0111,B0111,B0000,B0111,B0111,B0111,B0000,B0011,B0111,B0111,10,
B0000,B0000,B0000,B0000,B0000,B0111,B0111,B0111,B0000,B0111,B0111,B0111,B0000,B0111,B0111,B0111,10,
B0000,B0000,B0000,B0000,B0000,B1110,B1110,B1110,B0000,B1110,B1110,B1110,B0000,B1110,B1110,B1110,10,
B0000,B1110,B1110,B1110,B0000,B1110,B1110,B1110,B0000,B1110,B1110,B1110,B0000,B0000,B0000,B0000,10,
B0000,B1110,B1110,B1110,B0000,B1110,B1110,B1110,B0000,B1100,B1110,B1110,B0000,B0000,B0000,B0000,10,
B0000,B1110,B1110,B1110,B0000,B1100,B1110,B1110,B0000,B1000,B1100,B1110,B0000,B0000,B0000,B0000,10,
B0000,B1100,B1110,B1110,B0000,B1000,B1100,B1110,B0000,B0000,B1000,B1100,B0000,B0000,B0000,B0000,10,
B0000,B1000,B1100,B1110,B0000,B0000,B1000,B1100,B0000,B0000,B0000,B1000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B1000,B1100,B0000,B0000,B0000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B1000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B1000,B1000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1000,B1000,B1000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1100,B1000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1110,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1110,B0000,B0000,B0000,B0010,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0110,B0000,B0000,B0000,B0011,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0010,B0000,B0000,B0000,B0011,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0011,B0001,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0001,B0001,B0001,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0001,B0001,B0011,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1110,B0000,B0000,B0000,B1000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1100,B0000,B0000,B1000,B1000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1000,B0000,B0000,B1100,B1000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1110,B1000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1111,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0111,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0001,B0011,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0001,B0001,B0000,B0001,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0001,B0000,B0000,B0011,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0111,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1111,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1110,B1000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1100,B1100,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1000,B1110,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1111,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0111,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0011,B0000,B0000,10,
B0000,B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0001,B0000,B0000,10,
B0001,B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0011,B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0111,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1100,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1110,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B0011,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B0111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B1111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B1111,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B1111,B1100,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B1111,B1110,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1111,B1111,B1111,B1111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0111,B0111,B0111,B0111,B1000,B1000,B1000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0011,B0011,B0011,B0011,B0100,B0100,B0100,B0100,B1000,B1000,B1000,B1000,B0000,B0000,B0000,B0000,10,
B0001,B0001,B0001,B0001,B0010,B0010,B0010,B0010,B0100,B0100,B0100,B0100,B1000,B1000,B1000,B1000,10,
B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0010,B0010,B0010,B0010,B0100,B0100,B0100,B0100,10,
B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0010,B0010,B0010,B0010,10,
B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,B0001,10,
B0010,B0001,B0001,B0001,B0010,B0001,B0001,B0001,B0010,B0001,B0001,B0001,B0010,B0001,B0001,B0001,10,
B0100,B0010,B0001,B0001,B0100,B0010,B0001,B0001,B0100,B0010,B0001,B0001,B0100,B0010,B0001,B0001,10,
B1000,B0100,B0010,B0001,B1000,B0100,B0010,B0001,B1000,B0100,B0010,B0001,B1000,B0100,B0010,B0001,10,
B0000,B1100,B0011,B0000,B0000,B1100,B0011,B0000,B0000,B1100,B0011,B0000,B0000,B1100,B0011,B0000,10,
B0000,B0011,B1100,B0000,B0000,B0011,B1100,B0000,B0000,B0011,B1100,B0000,B0000,B0011,B1100,B0000,10,
B0001,B0010,B0100,B1000,B0001,B0010,B0100,B1000,B0001,B0010,B0100,B1000,B0001,B0010,B0100,B1000,10,
B0010,B0010,B0100,B0100,B0010,B0010,B0100,B0100,B0010,B0010,B0100,B0100,B0010,B0010,B0100,B0100,10,
B0100,B0100,B0010,B0010,B0100,B0100,B0010,B0010,B0100,B0100,B0010,B0010,B0100,B0100,B0010,B0010,10,
B0000,B0010,B0100,B0000,B0001,B0010,B0100,B1000,B0001,B0010,B0100,B1000,B0001,B0010,B0100,B1000,10,
B0000,B0000,B0000,B0000,B0000,B0010,B0100,B0000,B0001,B0010,B0100,B1000,B0001,B0010,B0100,B1000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0010,B0100,B0000,B0001,B0010,B0100,B1000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0010,B0100,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1000,B0000,B0010,B0000,B1000,10,
B0000,B0000,B0000,B0000,B0000,B0000,B0000,B1000,B0000,B0010,B0000,B1000,B0000,B0010,B1000,B0000,10,
B0000,B0000,B0000,B1000,B0000,B0010,B0000,B1000,B0000,B0010,B1000,B0000,B0000,B0000,B1000,B0000,10,
B0000,B0010,B0000,B1000,B0000,B0010,B1000,B0000,B0000,B0000,B1000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0010,B1000,B0000,B0000,B0000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0000,B1000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0100,B0010,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B0000,B0110,B0110,B0000,B0000,B0100,B0010,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
B1001,B0110,B0110,B1001,B0000,B0110,B0110,B0000,B0000,B0100,B0010,B0000,B0000,B0000,B0000,B0000,10,
B1101,B0111,B1110,B1011,B1001,B0110,B0110,B1001,B0000,B0110,B0110,B0000,B0000,B0100,B0010,B0000,10,
B1111,B1111,B1111,B1111,B1101,B0111,B1110,B1011,B1001,B0110,B0110,B1001,B0000,B0110,B0110,B0000,10,
B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1101,B0111,B1110,B1011,B1001,B0110,B0110,B1001,10,
B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1101,B0111,B1110,B1011,10,
B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,10,
B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B0000,B0000,B0000,B0000,10,
B1111,B1111,B1111,B1111,B1111,B1111,B1111,B1111,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
// this is a dummy element for end of table (duration=0) aka !!!DO NOT TOUCH!!!
B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, 0
** Defining pins in array makes it easier to rearrange how cube is wired
** Adjust numbers here until LEDs flash in order - L to R, T to B
** Note that analog inputs 0-5 are also digital outputs 14-19!
** Pin DigitalOut0 (serial RX) and AnalogIn5 are left open for future apps
int LEDPin[] = {13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 14, 15};
int PlanePin[] = {16, 17, 18, 19};
// initialization
void setup()
int pin; // loop counter
// set up LED pins as output (active HIGH)
for (pin=0; pin<PLANESIZE; pin++) {
pinMode( LEDPin[pin], OUTPUT );
// set up plane pins as outputs (active LOW)
for (pin=0; pin<CUBESIZE; pin++) {
pinMode( PlanePin[pin], OUTPUT );
// display pattern in table until DisplayTime is zero (then repeat)
void loop()
// declare variables
byte PatternBuf[PLANESIZE]; // saves current pattern from PatternTable
int PatternIdx;
byte DisplayTime; // time*100ms to display pattern
unsigned long EndTime;
int plane; // loop counter for cube refresh
int patbufidx; // indexes which byte from pattern buffer
int ledrow; // counts LEDs in refresh loop
int ledcol; // counts LEDs in refresh loop
int ledpin; // counts LEDs in refresh loop
// Initialize PatternIdx to beginning of pattern table
PatternIdx = 0;
// loop over entries in pattern table - while DisplayTime>0
do {
// read pattern from PROGMEM and save in array
memcpy_P( PatternBuf, PatternTable+PatternIdx, PLANESIZE );
PatternIdx += PLANESIZE;
// read DisplayTime from PROGMEM and increment index
DisplayTime = pgm_read_byte_near( PatternTable + PatternIdx++ );
// compute EndTime from current time (ms) and DisplayTime
EndTime = millis() + ((unsigned long) DisplayTime) * TIMECONST;
// loop while DisplayTime>0 and current time < EndTime
while ( millis() < EndTime ) {
patbufidx = 0; // reset index counter to beginning of buffer
// loop over planes
for (plane=0; plane<CUBESIZE; plane++) {
// turn previous plane off
if (plane==0) {
digitalWrite( PlanePin[CUBESIZE-1], HIGH );
} else {
digitalWrite( PlanePin[plane-1], HIGH );
// load current plane pattern data into ports
ledpin = 0;
for (ledrow=0; ledrow<CUBESIZE; ledrow++) {
for (ledcol=0; ledcol<CUBESIZE; ledcol++) {
digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) );
patbufidx++;
// turn current plane on
digitalWrite( PlanePin[plane], LOW );
// delay PLANETIME us
delayMicroseconds( PLANETIME );
} // for plane
} // while <EndTime
} while (DisplayTime > 0); // read patterns until time=0 which signals end
Step 11: 4x4x4 Cube Code With Shift Registers, Common Anode Version
// OCT32012 editing changes to adapt this program to work with shift registers,
// and to work with Common Anode LED cube. hippynurd@gmail.com
#include // allows use of PROGMEM to store patterns in flash
#define CUBESIZE 4
// blink on and off
// Just a note to say we dont do things this way anymore. Data is serialized
// to pin 7 via 74hc595 shift registers, and the planes(layers) are controlled
// by pins 11,10,9,6. The first shift register controls the first 8 pins, the
// second shift register controls pins 9-16.
// Looking down on the cube, the column pin matrix looks like this:
// 16 15 14 13
// 12 11 10 9
// 8 7 6 5
// 4 3 2 1
// My cube is common anode, meaning send 5 volts to the plane(layer), and ground
// the column to illuminate the individual led. This code was originally common cathode.
//OLD
//int LEDPin[] = {13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 14, 15};
//int PlanePin[] = {16, 17, 18, 19};
//NEW
int LEDPin[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
int PlanePin[] = {11, 10, 9, 6};
int dataPin = 7; //Data I added these for Shift Register
int clockPin = 12; // Clock
int latchPin = 13; // Latch
// initialization
void setup()
for (pin=0; pin pinMode( LEDPin[pin], OUTPUT );
// set up pins for serial output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
for (pin=0; pin pinMode( PlanePin[pin], OUTPUT );
void loop()
int PatternIdx;
int pinState; //pinState is used to send the correct bit to the data pin
PatternIdx = 0;
do {
// loop over planes
for (plane=0; plane // turn previous plane off (low is off, high is on)
if (plane==0) {
digitalWrite( PlanePin[CUBESIZE-1], LOW );
} else {
digitalWrite( PlanePin[plane-1], LOW );
ledpin = 0;
for (ledrow=0; ledrow for (ledcol=0; ledcol digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) );
patbufidx++;
// I used code from shiftout, to redo this to serialize the plane data
//ground latchPin and hold low for as long as you are transmitting
digitalWrite(latchPin, 0);
//move 'em out
ledpin = 0;
digitalWrite(clockPin, 0);
// digitalWrite( dataPin, PatternBuf[patbufidx] & (1 << ledcol) );
if (PatternBuf[patbufidx] & (1 << ledcol))
pinState= 0; // Flip these bits to suit your cubes common lead (cathode or anode)
else
pinState= 1; // Flip these bits to suit your cubes common lead (cathode or anode)
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState); // this is where data is sent to the shift register.
//register shifts bits on upstroke of clock pin
digitalWrite(clockPin, 1);
ledpin++;
patbufidx++;
digitalWrite(latchPin, 1);
// turn current plane on (plane high for on)
digitalWrite( PlanePin[plane], HIGH );
} // for plane
} // while } while (DisplayTime > 0); // read patterns until time=0 which signals end
Step 12: 4x4x4 Cube Code With Shift Registers, Common Anode Version
// and to work with Common Cathode LED cube. hippynurd@gmail.com
#define CUBESIZE 4
#define TIMECONST 10 // multiplies DisplayTime to get ms - why not =100?
// blink on and off
// 16 15 14 13
// 12 11 10 9
// 8 7 6 5
// 4 3 2 1
// This code is for common cathnode, meaning ground the plane(layer), and send 5 volts to
//OLD
//NEW
// initialization
void setup()
void loop()
int PatternIdx;
PatternIdx = 0;
do {
// loop over planes
for (plane=0; plane // turn previous plane off (low is on, high is off)
if (plane==0) {
} else {
ledpin = 0;
patbufidx++;
//move 'em out
ledpin = 0;
else
ledpin++;
patbufidx++;
} // for plane
