5 Plumbing Tricks You Gotta See!
5,742
8
5
About: Go check out my YouTube channel for more awesome learning videos, and don't forget to SUBSCRIBE to win some cool gifts! WWW.YOUTUBE.COM/GOT2LEARN
5 tricks you gotta see!
Step 1: IT WON'T BUDGE
Alright so if ever you’re trying to repair a piece of pipe that burst or what not and it ain’t budging, you don’t have a slip coupling either and need to get the system running in a rush, not a problem! Get yourself 4 elbows and reconnect everything back together, quite simple but good to know!
Step 2: MAJOR TOM
Whenever soldering a pipe, whether its ½” or 3” gravity can become an issue and using the right technique here is a must. In order to get passed this problem, solder your elbow on beforehand, then put it on your pipe and solder the other joint, this trick doesn’t work in space!
Step 3: I HATE SPIRALS
If ever you're using a big pipe cutter like this one, and this happens, your cutting starts making spirals on the pipe and you can’t seem to get it to cut through, here’s the fix. Run your cutter half way as such, then go in the opposite direction, eventually, you’ll get your pipe cut without making funny spirals on it!
Step 4: PLUMBER OR CARPENTER?
You need to cut a pipe but can’t seem to get it done because of the lack of space, go ask Mr.carpenter for his oscillating tool, he’ll gladly lend it to you, then go ahead and use it to cut thru your pipe without damaging the whole building!
Step 5: YOU CAN NOW KISS THE....GLUE?
And lastly, if you are doing a glue up project that requires a primer and a glue, this trick will save you a lot of steps, a headache, and money. Grab some tape, and tape both cans together, there’s no reason to have them separate, so why not keep them together forever!
Fix It! Contest
Fix It! Contest
    • Pets Challenge
      Pets Challenge
    • Sensors Contest
      Sensors Contest
    5 Discussions
    MikeT298
    9 months ago on Step 1
    Instead of using 4 elbows, one slip coupling will do the same thing. A slip coupling has no stop inside the middle of it. Make sure your pipe and fittings are first cleaned and fluxed than simply slip it all the way over one piece of pipe, align the 2 pieces and slide the coupling half way up the other pipe. That's only 2 soldier joints on one coupling instead of 8 on 4 elbows.
    JulioC150EcoExpatMike
    Reply 9 months ago
    A lot of people claim it's illegal to hide the product info, but in Canada I never had any problems, thanks buddy ;)
    FOOD by LydsJulioC150
    Reply 9 months ago
    You can design a bottle that has 2 compartments 1 for primer and 1 for glue. Then put both labels on the can. Million dollar idea XD.
    JulioC150FOOD by Lyds
    Reply 9 months ago
    I don't know why it wasn't already invented, we never need just one it's either both or nothing lol.
