Introduction: 50km/h Electric Skateboard
About: I am fascinated by inventions and by do-it-yourself. I share with you to find other passionate people.I have hundreds of projects in head but before continuing, I wish to know if my projects please
Hello to all, I present you my 4th very powerful electric skateboard, 1000w of power,I can push a person in bike with, 50 kph of top speed, 30km of autonomy, a truck before very handy.
Electrically, it is of the plug and play It is of the equipment of model making. This skateboard is very funny and reliable. I am a french maker and I hope that that will please you.
Step 1: Purchase of the Equipment
Motor: Turnigy Aerodrive SK3 - 5045-500kv Brushless Outrunner Motor
Esc controller : FVT Wolf 2-6s LiPo Batterie 120A Pro A imperméable Car Speed Controller ESC BEC
Battery : Multistar High Capacity 6S 10000mAh Multi-Rotor Lipo Pack
Remote : Quanum 2.4Ghz 3ch Pistol Grip Tx & Rx System
A longboard of your choice
charger : digital charger ap6 pro tronic and his supply
motor pulley:21 t5 10 teeth
wheel pulley:21 t5 36 teeth
belt: t5 245mm 3715 10mm
steel plate for battery box: 500x500x1,5 (mm)
steel plate for ventilator 50x50x0.5 (mm)
screw has wood (short)
steel screw
2 bearing of longboard
Step 2: Manufacture and Assembly
1 Drill the pulley of the engine in 6mm. Use a lathe. Drill and tap the side of the pulley to place a screw without head there anti rotation. Make a dish with a grinder on the axis of the engine to fix the small pulley
2 Make a ring with a lathe Then drill and tap to fix the plate to the truck
3 To drill with a lathe the big pulley and to drill there 3, to screw it on the wheel with screws has wood
4 To make a plate to fix the engine to the truck and position the engine of way has to have the tense belt. Use one screw of 8mm and 2 bearing of skateboard to tense the belt .
5 To make one steel battery box with a grinder and a welding machine big enought to put the battery, foam of protection and the radio receiver. Make a door on hinge to reach the battery and load it. To weld slices there to fix it with screws has wood .
6 Fix the esc with a wide collring ands crews has wood outside the box for the cooling
7 To make a ventilator in a plate of steel 0.5 mm in thickness of the shape of the engine, it comes to settle behind the engine with 3 screw. In turning point, makes the air circulate. This ventilator is very important for cooling the engine, otherwise, it risks to burn out
Step 3: TEST
The speed max is terrible, I run on average is 30 kph, but if I want to make the race, I accelerate and the adrenalin rises. I go as fast as cars in town. The board is big and high, wheels are big thus the board is stable and comfortable for the speed and the damaged roads, it's perfect.
The handiness of the truck before of origin was not enought raised, me the ais gift was replaced by handier one more rare.
I am not a skateboarder but to master an electric skateboard is easy because we do not put the foot on the ground and the acceleration is soft.
The engine warmed a little too much, thus I added a ventilator, it is essential, otherwise the engine roasts and the controller also.
No programming, no regulation, everything is simple
