8ft Icosahedron
8,367
70
16
Introduction: 8ft Icosahedron
About: My name is Jack Defay and I am a student and a maker! Check out my work on Youtube @jackandbendefayrobotics | Thingiverse @jackdefay | Github @jackdefay
You might be thinking, why build an 8 foot tall Icosahedron? For only $20 and a weekend, why not?
For this project all you will need is
- 150 ft of 1/2 in inner diameter PVC pipe
- access to a 3D printer
Step 1: What Is an Icosahedron?
The Icosahedron is a platonic solid like a cube or a tetrahedron. An Icosahedron is the largest of the platonic solids, made up entirely of equilateral triangle faces. This gives it strength and volume, which is why this shape is repeated so often throughout nature.
Platonic solids are just polyhedra with regular congruent polygon faces. Any connector piece will be symmetric and all of the connectors will be identical. This also means that all of the side lengths are equal. The symmetry makes them way easier to make!
Step 2: Connectors
This step might take a while because you have to wait for it to print. Check out my connector model on thingiverse:
https://www.thingiverse.com/thing:3403966
and print out 12 copies.
At first I printed these with 3 walls and 20% infill, which worked great for the 3ft icosahedron. The 3 wall connectors were a bit fragile for the longer pipes so I beefed them up to 5 walls. I've had trouble with 3D printed cylinders like this used to connect things, but the way it layers along the diagonal of the cylinders greatly improves the strength of the part.
I designed these in Solidworks to fit snugly in this size pipe. If you want to use a larger diameter pipe it should be straight forwards to scale it up to match. I've also included my earlier models for the tetrahedron and cube if you feel like making different gigantic shapes!
Step 3: PVC Pipes
I chose PVC pipe to form the edges of the shape because I needed a material that is cheap, strong, and comes in reasonably small tube shapes. I picked up 100ft of half inch internal diameter pipe at home depot for just over $10, this means with side length of 5ft, the 8ft Icosahedron costs only $15 in pipe.
To cut the pipe, I would definitely suggest investing in a ratchet. This is a simple tool that makes cutting the pipe a breeze. To cut the pipe, take a tape measure and a sharpie, mark the length and cut it with the ratchet. This could also be done with a hacksaw but seriously the ratchet was so much better.
These pipes come in 10ft lengths, which made 2ft and 5ft sides the natural choices. I first tried a 2ft length Icosahedron, which had a height of only about 3ft. This was cool, but I honestly thought it would be a little...bigger. So I bought some more pipe and cut 5ft lengths. Within the hour I had constructed an Icosahedron as big as my deck!
Step 4: Construction
Construction is super simple. For smaller sizes it's easy enough to do alone, but I found for the really big one a helping hand or two goes a long way. These connectors are friction fit, so all you have to do is cut the pipes to length and jam them in.
Each pipe fit a little differently. Some of them were perfect, some a little loose, and some nearly impossible to fit together. I found that they were hardly ever so loose that they fell out, but there were several pipes that I couldn't get all the way in. For the ones that were really stuck, I found twisting to work the best. Just make sure you're careful not to bend the connector as it can snap.
When assembling the big Icosahedron, one of the connectors broke and I repaired it with some duct tape. It's been outside for two weeks now and still holding great so I guess duct tape works well for this sort of thing! Also, I would advise printing backup connectors...
Step 5: Painting!
Painting the icosahedron takes it from cool to awesome.To paint the pipes properly you should clean them with a wet paper towel, sand with a fine grit sandpaper, wipe with acetone, prime and then paint. Honestly that's a lot of work so I just used an all purpose plastic primer and them painted. It worked great!
At first I tried spray painting it standing up but wasted a ton of paint to the wind. The next time I took it apart and laid the pipes next to each other to get better coverage. Gold looked great on the tetrahedron and I'll paint the big icosahedron when it warms up!
Epilog X Contest
Epilog X Contest
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    16 Discussions
    WoodNut0153
    WoodNut0153
    26 days ago on Step 5
    I'm not sure if anyone else might have even bothered to mention this, but...
    Your text "all purpose plastic primer and them painted."
    I think that you meant "and then painted."
    dirksq22
    dirksq22
    1 year ago
    I tryed this once without a 3D Printer not such good luck
    Like Natalia's comment, I would be interested in buying the corner 3D corner pieces.
    To make the Icosahedron. Could be a new business for you!
    Lcosahedrons are Us!
    Great Job!
    Thank you
    Dirk
    nataliar3
    nataliar3
    Reply 1 year ago
    Talk to us Jack. Can you print them and sell to us??
    JackDefay
    JackDefay
    Reply 1 year ago
    I'm sorry I'm in college and my printer is back home so I can't do the prints right now. I wish I could!
    Before I got my own printer I was able to do some at a local makerspace and some through a printing service that was linked on thingiverse. If you have any nearby makerspaces are usually happy to help, especially if you offer to bring your own filament or reimburse for the cost.
    I've been there too, I hope you figure it out!
    bluesdocbob
    bluesdocbob
    Tip 1 year ago
    you could have a large pot of water on a camp stove where you can heat the poly pipe ends to make them easy to fit if you strike tight bit..........
    JackDefay
    JackDefay
    Reply 1 year ago
    That's so cool! I'll try that out next time
    nataliar3
    nataliar3
    1 year ago
    Hello
    Would you be interested in selling the corner 3D PRINTED PIECES? To make the Icosahedron?
    I don't have access to 3D printer and would love to make this.
    thanks
    natalia
    nataliar3
    nataliar3
    Reply 1 year ago
    I would be interested in making this using COPPER piping instead of PVC. I know much more expensive but makes for amazing sculpture.
    JackDefay
    JackDefay
    Reply 1 year ago
    Wow copper pipes would looks amazing, if you make it please post pics!
    Gadisha
    Gadisha
    1 year ago
    Nice, but I' m not a fan of Pvc, would be cool to make something like this out of bamboo though...
    JackDefay
    JackDefay
    Reply 1 year ago
    Wow that would be so cool. Should be simple to scale the connectors to fit the bamboo too. If you make one please post some pics!
    AdrienR
    AdrienR
    1 year ago
    Ho nice! One month ago I did exactly this... but with a mistake with the angles. Then I did another project, thinking that I would come back later. But finally I will take yours.
    JackDefay
    JackDefay
    Reply 1 year ago
    Glad you like it! That connector looks great is it for a geodesic dome?
    ClarenceY
    ClarenceY
    1 year ago
    You should try to get your hands on some books by Buckminster Fuller, thought of as the father of the Geodesic Dome. I have some from the 60s-70s. He once proposed that Chicago should be enclosed by a dome. The books are filled with the geometry for every dome that you can imagine, both as enclosures and as homes.
    figacat
    figacat
    Question 1 year ago on Step 2
    can u send a link to the 3d files ?
    JackDefay
    JackDefay
    Answer 1 year ago
    All fixed!
