Introduction: ARDUINO Burglar Alarm Using Infrared Emitter-Detector Pair
In this tutorial i will show you , how to make a simple Inexpensive Intrusion Detection(Burglar alarm) using an Arduino Uno board . This project uses the Infrared Emitter-Detector pair to detect intrusion and triggers an alarm as soon as the object crosses the infrared field .
** To see a Similar Project Made with an LDR click here
**To see more simple arduino projects check out my blog
Step 1: REQUIREMENT :
- Arduino uno R3
- Breadboard
- Connecting wires / Jumper cables
- Infrared Emitter and Detector pair LED(not the sensor module)
- PCB mount BUZZER
- 1kohm Resistor
- 10kohm PotentiometeR
** the white LED is the Infrared emitter ,While the black is the Infrared Detector .
Step 2: CIRCUIT DIAGRAM :
Step 3: SOURCE CODE:
int dtect=8;
int sense=A0; int buzzpin=9; void setup() { pinMode(dtect,OUTPUT); pinMode(sense,INPUT); pinMode(buzzpin,OUTPUT); digitalWrite(dtect,HIGH); Serial.begin(9600); }
void loop() { int val=analogRead(sense); Serial.println(val); if(val>=1005) { buzz(50); } }
void buzz(unsigned char time) { analogWrite(buzzpin,170); delay(time); analogWrite(buzzpin,0); delay(time); }
Step 4: DISCUSSIONS :
First build the circuit according to the circuit diagram provided .
Now i will explain to you how the circuit works .
- The white Led you see in the pictures is an Infrared Emitter . You power it on like a normal LED .
- Now if this is your first time with an IR Led , its very common that you'll mistake your LED to be spoiled as you wont find it glowing ,but that isn't the case really .
- Infrared light is out of the visible spectrum range so even if it is glowing , you wont be able to see it with naked eyes.
- To see if your emitter LED(White) is working properly : switch on your cell phone camera and see the LED through it , you will see that there is a purple Glow .
- This ensures that your IR emitter (White ) is working perfectly and it is emitting light of a particular range of frequency . Now lets come to the Black LED .
- The back LED is the IR detector. The reason that it is made black is that Black color has the highest absorption ; so it Absorbs most of the infrared light Emitted by the Emitter .
- Now what happens if an object stands in between the Emitter and the detector ?? . OBVIOUSLY the amount of infrared radiations intercepted by the detector will now be lesser due to the obstruction .This is the catch !! .
- When such a situation occurs , I trigger the alarm to denote Intrusion .
Now that you've got your concept right , LETS FOCUS ON THE CODE .
- In line 10 we begin the serial communication to see the values being intercepted on the serial monitor for both the cases i.e
- case 1.) no obstruction in the path of the emitter and the detector .
- case 2.)obstruction in the path of the emitter and the detector .
- for both these cases , we have to observe the values being reflected on the serial monitor , based on which we will decide for which value being exceeded we will be triggering the alarm .
- Note that for my experiment the threshold value was set to 1005 . This might not be the case for you. Hence try to monitor the values that you are intercepting and choose your threshold accordingly .
**Well , hope I have covered all the concepts in detail regarding this project . If you face problems or if you need further detailing on any sub-topic , then please do leave me a comment .
Step 5: PROJECT VIDEO :
Thank you all for watching .
Epilog Challenge VI
Teach It! Contest Sponsored by Dremel
