Introduction: Arch Linux on Raspberry Pi
On this tutorial I will be showing you how I would install Arch Linux on my raspberry Pi. Since there are many different approaches to what could be configured there is no right or wrong way to install this. Thanks
Step 1: Prepare the SD Card and Install Arch Linux
on linux PC:
lsblk
sudo fdisk /dev/sdX
clear partitions on the drive (o)
create first partition (n, p, 1, enter, +100M, t, c)
create second partition (n, p, 2, enter, enter), then write and exit (w)
sudo mkfs.vfat /dev/sdX1
sudo mkfs.ext4 /dev/sdX2
make folder to mount partitions
mkdir /mnt/boot/
mkdir /mnt/root/
sudo mount /dev/sdx1 /mnt/boot/
sudo mount /dev/sdx2 /mnt/root/
download and install arch
wget http://archlinuxarm.org/os/ArchLinuxARM-rpi-2-latest.tar.gz
sudo su
tar zxvf /location/of/file/ArchLinuxARM-rpi-2-latest.tar.gz -C /mnt/root
mv /mnt/root/boot/* /mnt/boot
sync
Step 2: Init
On Raspberry Pi:
login: root
password: root
setting up wifi with wpa_supplicant
sudo nano /etc/wpa_supplicant/home_wifi
add following and edit ssid and psk with your old network info
network={
ssid=”neworkname”
psk=”password”
}initiating pacman, upgrading arch and install sudo
pacman-key –init
pacman -Syu
pacman -S sudo screen
nano /etc/sudoers.d/myOverrides
add following
alarm ALL=NOPASSWD: ALL
switch to user alarm:
su alarm
Step 3: Installing Desktop
install packer for additional software down the road
sudo pacman -S packer
now lets install the desktop
sudo pacman -S xorg-server xf86-video-fbdev xorg-xrefresh
leave everything as default
XFCE4:
sudo pacman -S xfce4 xfce4-goodies
now we need desktop manager:
sudo pacman -S sddm
we are going to load default configs with this command
sudo sh -c “sddm –example-config > /etc/sddm.conf”
autologin:
sudo nano /etc/sddm.conf
search and modify:
[autologin] Session=xfce.desktop User=alarm
custom theme i’m using
packer -S arc-gtk-theme
custom fonts
packer -S ttf-roboto
SDDM autostart:
sudo systemctl enable sddm
sudo systemctl start sddm
Step 4: Network Manager
lets install a network manager so you can control your wifi or ethernet via gui
sudo pacman -Syu networkmanager network-manager-applet
sudo systemctl enable NetworkManager
sudo systemctl start NetworkManager
reboot
Step 5: Bluetooth
lets install the tools we need to compile bluetooth
sudo pacman -S make gcc git-core automake autoconf pkg-config libtool patch
packer -S yaourt blueman
yaourt -S pi-bluetooth
sudo systemctl start bluetooth.service
sudo systemctl enable bluetooth.service
sudo systemctl enable brcm43438.service
sudo pacman -Syu pulseaudio-alsa pulseaudio-bluetooth pavucontrol bluez bluez-libs bluez-utils bluez-firmware
